Trying to sort out oil pressure gauge problem, mechanical gauge showed 40-50, but stock gauge shows about 10. swapped out circuit board, put in new digital Right Time Engineering 5 Volt next because fuel was low too. No Change. easiest swap is new sending unit. any local sources or part numbers? any big block or small block should work I think? Thanks Greg
