727 shifting too quick??? #382699
07/21/09 09:52 PM
07/21/09 09:52 PM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
I have a 727 of unknown vintage(older I think) and it seems to me that under normal acceleration that it shifts from 1st to 2nd to 3rd really quick. So quick that when I first started to drive my car I thought it was stuck in 2nd. I had to listen really hard to hear it change into 3rd. I had it rebuilt some 4 years ago with no mods; it has a "stock" MP torque converter and is hooked to a 3:55 rear gear. So what gives?
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
Re: 727 shifting too quick??? [Re: BFASTER] #382700
07/21/09 10:01 PM
07/21/09 10:01 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
At what speed is the trans shifting gears? .. throttle linkage adjusted properly ?
Re: 727 shifting too quick??? [Re: dOc !] #382701
07/21/09 10:18 PM
07/21/09 10:18 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
under normal accelleration shift should be 1/2 @ 18
2/3 @ 28.
Where is your throttle pressure linkage set and do youhae teh small spring holding the rear of the slot to the carb throttle pin so that you have constant progressive throttle pressure. This is what regulates the shift points.
Re: 727 shifting too quick??? [Re: dOc !] #382702
07/21/09 10:28 PM
07/21/09 10:28 PM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
It shifts at very low speeds-I can be in 3rd before I hit 25mph! As far as linkage goes, it should be OK. Everything else related to the carb is fine. Or did you mean the kickdown linkage?
Re: 727 shifting too quick??? [Re: MoparforLife] #382703
07/21/09 10:30 PM
07/21/09 10:30 PM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
2/3 @ 28.
I will check out that throttle pin.
Re: 727 shifting too quick??? [Re: BFASTER] #382704
07/21/09 10:34 PM
07/21/09 10:34 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
At light throttle... into 3rd by 25mph isn't bad. But under heavy throttle or WOT .. not good.
TP linkage same/same as KD linkage.
Re: 727 shifting too quick??? [Re: BFASTER] #382705
07/21/09 10:36 PM
07/21/09 10:36 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Normal. My 727 putters around at 1500rpm @ 30mph. Why do you think you'd need to wind it out any higher? Even my 4cyl 2.5 TBI with a 3sp torqflite fwd trans shifted at around those same speeds. So long as it downshifts when you nail the throttle it's fine. Also when I go full throttle mine winds itself out to 5000 before it shifts on its own.
Re: 727 shifting too quick??? [Re: BFASTER] #382706
07/22/09 12:25 AM
07/22/09 12:25 AM
My car shifted exactly like that till a week ago when I re adjusted it. Check out this link. Go to 1971 car and linkage adjustment. I think mine is close to 1/2 play at the rod now. A few tuns of the rod change the shifting of the tranny when you are close. A few trips down the road and you will have it how you want. Kick down in my car now works too.
http://www.imperialclub.com/Repair/Lit/Master/index.htm
Re: 727 shifting too quick??? #382707
07/22/09 02:03 AM
07/22/09 02:03 AM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
Comment edited: uncalled for and triggered the downward spiral of this thread
Re: 727 shifting too quick??? [Re: BFASTER] #382708
07/22/09 02:06 AM
07/22/09 02:06 AM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
Irrelevant to post, try to stick to the topic at hand please. Thanks!
Re: 727 shifting too quick??? [Re: DaytonaTurbo] #382709
07/22/09 09:38 AM
07/22/09 09:38 AM
New Mexico
74Scamp Offline
74Scamp  Offline
New Mexico
Ummm, not to try and start something here, but I think what DaytonaTurbo was saying is "Why do you think "you would" need to wind . . . ." "You'd" is "short" for You Would.
Re: 727 shifting too quick??? [Re: BFASTER] #382710
07/22/09 10:08 AM
07/22/09 10:08 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: 727 shifting too quick??? [Re: Junky] #382711
07/22/09 10:40 AM
07/22/09 10:40 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
(Irrelevant to post, try to stick to the topic at hand please. Thanks! )
He's right, into 3rd at about 25 mph about correct under light accelleration.
Re: 727 shifting too quick??? [Re: BFASTER] #382712
07/22/09 04:04 PM
07/22/09 04:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The factory spec for the 2-3 shift is under 20 mph so yours is actually shifting late.
Re: 727 shifting too quick??? [Re: 74Scamp] #382713
07/22/09 05:05 PM
07/22/09 05:05 PM
Manitoba, Canada
Manitoba, Canada
Re: 727 shifting too quick??? [Re: DaytonaTurbo] #382714
07/22/09 08:07 PM
07/22/09 08:07 PM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
Re: 727 shifting too quick??? [Re: DaytonaTurbo] #382715
07/22/09 08:09 PM
07/22/09 08:09 PM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
Re: 727 shifting too quick??? [Re: BFASTER] #382716
07/22/09 08:16 PM
07/22/09 08:16 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
shifting into 3 by 25 sounds about right but not feeling it [Edited by Moparts - Family Friendly Site - Keep it clean] sounds like a problem. Check the adjustment on your kickdown. It controls trans presure.
Re: 727 shifting too quick??? [Re: BFASTER] #382717
07/25/09 12:00 PM
07/25/09 12:00 PM
Sacramento, CA, USA
steeters Offline
steeters  Offline
Sacramento, CA, USA
If I can hijack this for a moment...
I too am experiencing an issue with a shift point that I believe is too early. It is a rebuilt, zero miles, Torque Command (AMC) 727 with a transgo shift kit.
I have what resembles the Mopart multi-segment throttle pressure linkage.
There's is about 1/3" of slack in the carburetor link bar before the throttle will start pulling forward on the throttle rod.
I got this much slack by pulling all the way forward on the throttle rod, and opening the carburetor linkage to full throttle and tightening down the nut on the carburetor link bar.
Since the shift seems too early to me, can I just add a little more slack in the carburetor link bar so that maybe 3/4" of throttle travel will occur before pulling forward on the throttle rod?
Thanks!
Steve
AMC Fan '70 Javelin SST 390 (now 401 with TC727)
Re: 727 shifting too quick??? [Re: steeters] #382718
07/25/09 04:46 PM
07/25/09 04:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You say the carb "pulls" the throttle rod?
Mopars push the linkage, and the back of the carb stud must remain in constant contact with the rear of the slot on the top rod.
However your linkage is configured, to get later shifts you want the transmission lever further to the rear for any given throttle opening.
