Re: Vacuum advance distributor vacuum hose goes?
[Re: 1fastrunner]
#382515
07/21/09 08:45 PM
07/21/09 08:45 PM
Posts: 21,855 Kirkland, Washington
Pacnorthcuda
When setting my initial I just keep the vacuum hose to the distributor unplugged? Do the ported and manifold vacuum ports get plugged for setting timing? When the distributor vacuum advance gets plugged in, does it go to the manifold or ported vacuum port? When setting idle mixture screws, I use manifold ported vacuum? Sorry about all the questions, but I just want to be sure I'm doing it the correct way. Thanks,
1) The hose to the distributor does not need to be plugged. The carburator side should be plugged. 2) You want PORTED vacuum for the distrubutor (above the T-plates) 3) When setting mixture you want the gauge to be connected to FULL manifold vacuum
[Re: Pacnorthcuda]
#382516
07/21/09 11:02 PM
07/21/09 11:02 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Yes, disconnect and plug the vacuum leak (hose if you took it off the dist., port if you took it off the carb), Stock was ported, and adjust carb with the advance hose connected, and use the vacuum gauge connected to manifold vacuum. There was an interesting discussion about timing and how it can affect engine temps here... http://www.jalopyjournal.com/forum/showthread.php?t=374847
[Re: RodStRace]
#382517
07/22/09 08:04 AM
07/22/09 08:04 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Ported is more popular and the way our cars were sent out of the factory but that does not mean manifold vacuum advance is incorrect.
It offers some advantages over ported. More ignition timing for idling.
Both offer higher ignition timing at highway cruise and both drop back to full mechanical at wide open throttle.
My engine idles better at 50 deg than 30. That's why I run manifold.
