727 Trans will not shift. #382199
07/21/09 03:54 PM
07/21/09 03:54 PM
duals Offline OP
duals  Offline OP
Just bought a 1972 Demon 340, now has a 400, 40 over, etc. anyway the trans has a shift kit (?) hits second hard but it will not shift into third. I think it went in one time when I hit it on a rolling start, it shifted into all 3 gears. I have tried puting it in drive and manually shifting it with same results, could they have it set up for drags ? I have had it up to 60 in second and no shift Thanks
Re: 727 Trans will not shift. [Re: duals] #382200
07/21/09 05:28 PM
07/21/09 05:28 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
How is your kickdown(throttle pressure )linkage adjusted?
Re: 727 Trans will not shift. [Re: stumpy] #382201
07/21/09 05:30 PM
07/21/09 05:30 PM
duals Offline OP
duals  Offline OP
At the engine or at the trans, ?
Re: 727 Trans will not shift. [Re: duals] #382202
07/21/09 05:33 PM
07/21/09 05:33 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
What is the quality of the engagment of the trans into reverse?
Re: 727 Trans will not shift. [Re: dOc !] #382203
07/21/09 05:34 PM
07/21/09 05:34 PM
duals Offline OP
duals  Offline OP
No prob. into reverse. When in drive it shows to the left of D.
Re: 727 Trans will not shift. [Re: duals] #382204
07/21/09 05:38 PM
07/21/09 05:38 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What did you do to set the kickdown linkage. How did you adjust it? How far does it move at full throttle?
Re: 727 Trans will not shift. [Re: duals] #382205
07/21/09 05:41 PM
07/21/09 05:41 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
I would double check to see where the shift lever is on the trans .... when the column shifter is in that position.
Re: 727 Trans will not shift. [Re: duals] #382206
07/21/09 06:32 PM
07/21/09 06:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's possible that converting from the SB to the BB they got the TP linkage wrong. Just to be sure, temporarily disconnect the TP linkage at the transmission lever and see if it will shift to 3rd.
If it goes into third with the linkage disconnected the linkage is the problem. SB linkage won't work on a BB.
Re: 727 Trans will not shift. [Re: John_Kunkel] #382207
07/21/09 07:17 PM
07/21/09 07:17 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Mine didn't want to go into 3rd at WOT because of an improperly adjusted kickdown.
Re: 727 Trans will not shift. [Re: DaytonaTurbo] #382208
07/21/09 08:43 PM
07/21/09 08:43 PM
grant louisiana
mayhem148 Offline
mayhem148  Offline
grant louisiana
definately sounds like a linkage problem. kickdown or column. i know if the kickdown is just a little off sometimes it will do just what you are saying. but they do have a shift kit and if adjustments dont work i would check the valve body to see if its together right. something not tellin the trans to go in third. if the band or clutches were burnt reverse would be sluggish or not work at all. shouldnt be nothin major.
Re: 727 Trans will not shift. [Re: mayhem148] #382209
07/21/09 08:49 PM
07/21/09 08:49 PM
duals Offline OP
duals  Offline OP
Think all of you have hit the nail on the head, switching to a big block they never tried to run a kickdown leverThe one on the car goes no where, will have to fabricate some kind of kickdown, any ideas the old one is hitting the firewall.
Re: 727 Trans will not shift. [Re: duals] #382210
07/21/09 10:10 PM
07/21/09 10:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Bouchillon and lokar make a cable set ups for that. If you don't fix it real quick you will burn up the trans. The throttle pressure(kickdownn) linkage controls the pressure in the trans. Without it you will have low pressure and burn up the bands and clutchs. Just like slipping or riding a manual clutch. Bouchillon is more expensive but is easier to install Lokar takes some playing and repositioning of the cable attaching point on the trans lever.About 3/4" in from the original hole on my A518 with an edelbrock carb using the mopar carb adapter.
Re: 727 Trans will not shift. [Re: stumpy] #382211
07/21/09 11:17 PM
07/21/09 11:17 PM
duals Offline OP
duals  Offline OP
Going to start looking tomorrow at the mess they have now and try to figure it out.
Re: 727 Trans will not shift. [Re: duals] #382212
07/22/09 12:31 PM
07/22/09 12:31 PM
duals Offline OP
duals  Offline OP
Besides the Lokar kit, what else will I need to mount it to the intake ?
Re: 727 Trans will not shift. [Re: duals] #382213
07/22/09 01:30 PM
07/22/09 01:30 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It depends what carb you have. The kit comes with the brackets you will need to mount to the existing intaske bracket but if you are running an Edelbrock or Holley carb you will need an adapter. You should be able to get it at most large parts stores.
Re: 727 Trans will not shift. [Re: stumpy] #382214
07/22/09 01:49 PM
07/22/09 01:49 PM
duals Offline OP
duals  Offline OP
Thanks, running a Holley.
Re: 727 Trans will not shift. [Re: duals] #382215
07/22/09 03:55 PM
07/22/09 03:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If there is no TP linkage hooked up at all it should shift very early to all gears. If, indeed, there is no linkage and it won't shift to 3rd it's a different problem.
Re: 727 Trans will not shift. [Re: John_Kunkel] #382216
07/22/09 05:25 PM
07/22/09 05:25 PM
duals Offline OP
duals  Offline OP
What I have looked at today, only under the hood as it has rained all day, is there is the kickdown TP, lever attached to the manifold, no return spring to anywhere and when you manually pull it toward the firewall it hits the lower wall. Can't tell if it is hooked to the trans or not, so I guess where ever the trans lever wants to be it has full range if hooked tothe old TP
Re: 727 Trans will not shift. [Re: duals] #382217
07/22/09 07:24 PM
07/22/09 07:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Even if the linkage was hooked up and correct the absence of a spring to pull the linkage forward will cause late or no upshifts. The weight of the linkage makes it want to push the transmission lever to the rear so it needs the spring to pull it forward.
Check the archives for some examples of linkage setups:
http://www.moparts.org/Tech/Archive/auto/35.html
