Anyone use Elgin bigblock valve spings? #381855
07/20/09 11:18 PM
07/20/09 11:18 PM
Round lake, IL
ra340 Offline OP
ra340  Offline OP
Round lake, IL
I was checking out things on epay and came across some one selling Elgin big block mopar valve spings rated for up to .555 lift. part number rv-9907S After reading the desciption again I realized these springs also fit big block chevy. After reviewing intalled spring heights I think .535 is the max lift for these springs on a mopar. Are these springs worth trying on a buget build or is this a classic case of you get what you pay for?
Re: Anyone use Elgin bigblock valve spings? [Re: ra340] #381856
07/20/09 11:27 PM
07/20/09 11:27 PM
North Chicagoland
N
newbee69 Offline
newbee69  Offline
N
North Chicagoland
dont bother....springs arent that much anyways. you should know from being around the area, that anything with the name Elgin sux.
BTW, Im right down the block from you in Lakemoor.
Re: Anyone use Elgin bigblock valve spings? [Re: newbee69] #381857
07/21/09 08:56 PM
07/21/09 08:56 PM
Round lake, IL
ra340 Offline OP
ra340  Offline OP
Round lake, IL
I suspect the springs are not made in Elgin. I was just wondering if anyone had used these springs. $29.99 seems inexspensive for 16 valve springs. Can you recomend another set of affordable big block valve springs that will support a cam with around .510 lift?
