Suggestions needed- squeal noise at idle??????? #381091
07/20/09 02:05 PM
07/20/09 02:05 PM
Bixby
Jimmys63Savoy Offline OP
Bixby
Guys, we are talking about a 11.50 second 440 with hyd. cam
Bought the car a few months back, I don't have very much history on it, now it started making a very loud moan/squeal only at idle, if you bring it 100 rpm off idle it's gone. Seems to be coming from the back of the engine/transmission area.
I have ruled out the water pump & alternator bearing being shot. It also doesn't matter if it is in gear, neutral or park.
Any suggestions without tearing it down? Would you lean towards engine or tranny?
Thanks in advance
Re: Suggestions needed- squeal noise at idle??????? [Re: Jimmys63Savoy] #381092
07/20/09 02:08 PM
07/20/09 02:08 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
vacuum leak?
Re: Suggestions needed- squeal noise at idle??????? [Re: S/ST 3040] #381093
07/20/09 02:10 PM
07/20/09 02:10 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Sure it isnt a belt slipping/loose??
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Post deleted by Defbob [Re: S/ST 3040] #381094
07/20/09 02:14 PM
07/20/09 02:14 PM
Re: Suggestions needed- squeal noise at idle??????? #381095
07/20/09 02:31 PM
07/20/09 02:31 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
It's Fred when he finds the key to the sheep barn. But seriously we had an engine do that and drove a bunch of us nuts,turned out to be a bad PVC valve and the engine was trying to vent it self at the rear main seal.Try taking the breathers or PVC valve off and letting the engine vent at the valve covers.If you think it's the belt remove it and listen for the squeel. I assume you check for anything rubbing(mechanical)
Re: Suggestions needed- squeal noise at idle??????? #381096
07/20/09 02:32 PM
07/20/09 02:32 PM
Bixby
Bixby
Thanks guys, it's not the belt, Mr. HEMIFRED, about the possibility of loose converter bolts, this is a condition that would go away off idle?
Very interesting, I'm going out to jack it up & check them right now.
Re: Suggestions needed- squeal noise at idle??????? [Re: Jimmys63Savoy] #381097
07/20/09 02:37 PM
07/20/09 02:37 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Converter bolt generally make a knocking sound like a bad connecting rod.
Re: Suggestions needed- squeal noise at idle??????? [Re: Jimmys63Savoy] #381098
07/20/09 02:39 PM
07/20/09 02:39 PM
Bixby
Bixby
WOW!!!!
I got the famous HEMIFRED and BOB GEORGE to reply to a thread.....I am honored.
Mr. George, my dad still has the hemi cuda in Latrobe, i'm waiting for him to get just a little older so maybe I will get to add that car to my stable down here in Oklahoma.
Thanks guys I'm going to go get busy.....
Re: Suggestions needed- squeal noise at idle??????? [Re: Jimmys63Savoy] #381099
07/20/09 03:01 PM
07/20/09 03:01 PM
Bixby
Bixby
Problem solved!!!!!!!
Thanks HEMIFRED, E V E R Y converter bolt was loose, one almost ready to come out.
Guess I better go over this whole car real good before I take it out this weekend for the first time.
Re: Suggestions needed- squeal noise at idle??????? [Re: Jimmys63Savoy] #381100
07/20/09 03:11 PM
07/20/09 03:11 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
Converter bolts + red loc-tite =
Re: Suggestions needed- squeal noise at idle??????? [Re: Jimmys63Savoy] #381101
07/20/09 08:04 PM
07/20/09 08:04 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
WOW!!!!
