Page 4 of 4 1 2 3 4
Re: Classic events 10 flat shootout thoughts [Re: 440Jim] #380947
07/22/09 07:41 PM
07/22/09 07:41 PM
412 SB Duster Offline
With the delay box you still have to let go of the button just like any trans brake car with out a box. If your late your late with or without a box. The only difference is how you adjust to get the the light you want. Without a box you change the car to get the lite you want within the limits of the car. The delay box does the same thing.
Re: Classic events 10 flat shootout thoughts [Re: 412 SB Duster] #380948
07/22/09 07:48 PM
07/22/09 07:48 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
it is just more simple to electronically setup your rollout.
Re: Classic events 10 flat shootout thoughts [Re: wheelsup68dart] #380949
07/22/09 07:50 PM
07/22/09 07:50 PM
I think some people think a delay box automatically means .00 lite
Re: Classic events 10 flat shootout thoughts [Re: 412 SB Duster] #380950
07/22/09 08:30 PM
07/22/09 08:30 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
412 SB Duster, I am right with you and Lonnie on your thinking,next thing someone will suggest a change to a Box 10.00 and a no box 10.00 race,,,and as far as a light car having an advantage, then ask Lonnie how my 3150# car does against his 2500# car, it's a drivers race any way you cut it, if your car will run the number then it's up to the driver to make it happen.
Re: Classic events 10 flat shootout thoughts [Re: wheelsup68dart] #380951
07/22/09 09:45 PM
07/22/09 09:45 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Taking the delay box out and going to .500 pro tree makes it unfair to the lite wt faster cars.
then does that not create a disadvantage to a car like mine who can in no way not go red on a .500 tree, I don't even think that a 33x10.50x15 tire on front would give me enough rollout to stay green. I ask, how is this a fair solution? A delay box would now allow me to go .00? on the tree just like every other car in the class right? So why do we still act like a bunch of schoolyard bullies. I can agree to thinking a .500 tree is acceptable if you all can stop crying that a delay box is an unfair advantage, when all the delay box does is add the rollout that your car has built into it.
Man, you are kidding right? I don't care what the rules are or what they are changed to, if changed at all. You've done very well in this class and I don't blame you for not wanting things changed, but........
"does that not create a disadvantage to a car like mine who can in no way not go red on a .500 tree"
NMCA Open Comp is run on a .500 tree - no delay box. There are plenty of light cars there that are faster than yours who run that class without red lighting.
"I can agree to thinking a .500 tree is acceptable if you all can stop crying that a delay box is an unfair advantage"
Did you really say that? The only reason a delay box wasn't an advantage on a .400 tree is because most high 9, low 10 second bracket cars couldn't possibly red light on that tree. ANY OTHER TIME you pit box cars against no box cars, the delay box guys gain a big advantage.
I'm just a neutral 3rd party here. It's been interesting reading some of the responses, but those arguments are just not realistic. Especially coming from someone with as much racing experience as you seem to have.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: Classic events 10 flat shootout thoughts [Re: nhramark] #380952
07/22/09 09:58 PM
07/22/09 09:58 PM
Columbus, Ohio
Columbus, Ohio
My response was quite simply put, on a .500 tree there is no way I can add enough rollout to stay green, unless I were to add 30" tall tires and throw some 500 plus pounds in the car, not gonna happen, I'll just stop running the class and I won't cry about it. However if you think it is not an advantage to those bottom bulb racers who are already set up for a .500 full tree bottom amber flash then you my friend are insane. Again I am sure that I could make my car react without the delay box(rollout box) to hit the tree, but not in a feasible way to switch between that and bracket mode. It is funny how things have gotten misinterpreted. I said that I was okay with going to .500 tree, it does not bother me, anyone that knows me at the track knows that I am a huge advocate for close races. I get very little satisfaction out of non close races, and was very congratulatory of Pat Norton for the butt kicking he laid on me at Martin. I don't see there being a easy equalizer for the heavy cars to cut a .400 tree, but if they go to .500 it will be extremely easy for them to go .00 to .01 and an easy equalizer for the light weight cars is to allow the rollout box to make them leave no different than the heavy cars. Lets party, lets everyone get off the line with .00 lights and see what happens at the stripe, makes no difference to me. And yes I was being sarcastic about the Super Gas cars since they all seem to be running 150mph and are capable of launching under 1.24 60'.
Please don't take all my comments out of context
Re: Classic events 10 flat shootout thoughts [Re: wheelsup68dart] #380953
07/22/09 10:31 PM
07/22/09 10:31 PM
Taylor, Michigan
1BadLiLCharger Offline
Taylor, Michigan
Lonnie, get the Biondo button and you wouldn't need the delay box. Use the full travel of the button and you'll be fine. I'm thinking that .100 difference will be the fact that we can't see the tree coming down and you won't react as quick to the 3 yellows coming on at the same time, so between that and the longer traveling button, we'd be fine.
Post deleted by Defbob [Re: wheelsup68dart] #380954
07/22/09 10:52 PM
07/22/09 10:52 PM
Re: Classic events 10 flat shootout thoughts #380955
07/22/09 11:15 PM
07/22/09 11:15 PM
Portage,michigan
B3422W5 Online content OP
B3422W5  Online Content OP
Portage,michigan
the advantage a light car like you have lonnie is that it reacts way quicker and is going to 60 foot better than the typical 10 flat car like mine.
how many pro stock guys go red racing 2350 pound cars on a 400 tree ?
its way easier to judge a race getting out on everybody than it is being behind,that isnt a big secret coming. out of the gate.a light car is going to move quicker, and 60 foot way better..my car would go mid 1.20's if it weighed even 2800-2900 pounds
i think you are a great friver and would do good no matter the rules, but its insanely silly to think guys dont have one hand tied bhind their backs going to the line in a heavy car without a box,on a 400 tree
how many nhra 9.90 class cars do you see without a box that weigh over 3000 pounds..none, they know they would never win with that handicap, good driver or not.
i really guess i dont care about the weight of all the cars, or even a delay box(although other 10 flat races i have ever been in dont allow boxes and have minimum weights)the reason is beacuse they want it to be fair for everybody so they get good car counts.
i say go 500 tree, lets give everybody a swing at a 00 light that can hit the tree and let the driver, not the car and electronics decide it.
thinking any other way is flat out disingenious,you know it and i know it...
nhra mark hit the nail on the head in his post.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Classic events 10 flat shootout thoughts [Re: wheelsup68dart] #380956
07/22/09 11:40 PM
07/22/09 11:40 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
I did not take any of your comments out of context. I acknowledged that your last point may have been tongue in cheek, and I have edited that out of my post. I'm not trying to pick an argument with you, so please don't take it that way.
I just don't agree that you couldn't make your car launch on a .500 tree without a box. Thing is though, on that tree MOST of the cars could red light.
Right now though I can almost see John Cope ripping his hair out. He and I put together the wheelstander class at the Nats one year. That was a good idea on paper, but hard to regulate.
John put the ten-oh class together because it was simple.
Pro tree
10.00 index
low entry/ small payout
FUN
NO HEADACHES
I hope you guys figure it out before it gets ruined.
Re: Classic events 10 flat shootout thoughts [Re: nhramark] #380957
07/22/09 11:52 PM
07/22/09 11:52 PM
ok first off I didnt read the WHOLE thing so excuse me if this has already been stated.
I just dont get how light cars or delay boxes or anything have an effect on this race. You are allowed to deep stage right? if so why cant the "less advantaged" cars just deepstage and cut a light?
I think the rules should be left alone... its a great class with more and more cars every event
Casey
Re: Classic events 10 flat shootout thoughts #380958
07/23/09 06:53 PM
07/23/09 06:53 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Hopefully that pot stirring guy means you said this tongue in cheek. 9.90 super rod/super gas cars are high dollar, high horsepower, purpose built for that class and have little in common with a typical bracket car that would run this ten-oh class.
Not all of them...
I think that what is missed here...from a bystanders viewpoint. ...is that some of these cars in this class
A...can't run the #
B...can't cut a light on a .400
If I were interested in doing this..I would concentrate on A&B....not on changing the rules on a yearly basis. There are some easy things that some of the guys can do to get closer to a .400 and although it's not always as easy finding a couple of tenths of ET can be done also.....
Re: Classic events 10 flat shootout thoughts [Re: nhramark] #380959
07/23/09 11:02 PM
07/23/09 11:02 PM
central Ohio
SnakeEisz67 Offline
SnakeEisz67  Offline
central Ohio
"Right now though I can almost see John Cope ripping his hair out."
Was thinking same thing. If this becomes too much of a pain why would anyone want to deal with it? Valid points have been made. I'm sure John & Eddie are aware of them. Must this be to death?
Re: Classic events 10 flat shootout thoughts [Re: SnakeEisz67] #380960
07/24/09 10:56 AM
07/24/09 10:56 AM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
Well, I still have all my hair, and if the vote at Norwalk goes .500s tree, I am ok with that.
It would be nice if all the CRT 10.Os have the same rules, this year the 10.O will be at Monster Mopar, and I am going to work on getting Mop Nats for 2010. Yes at times it can be a pain, but I feel it worth it. For the most part, all us 10.O racers have fun, and are good buddies. In the end I would like to see the 10.O grow in car count, and everybody have fun racing.
Re: Classic events 10 flat shootout thoughts [Re: CRT] #380961
07/24/09 11:02 AM
07/24/09 11:02 AM
Ohio
E
eddie_ccevents Offline
E
Ohio
I still got my hair. What the kids have left that is.
Re: Classic events 10 flat shootout thoughts [Re: eddie_ccevents] #380962
07/24/09 11:03 AM
07/24/09 11:03 AM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
Hehehe
Re: Classic events 10 flat shootout thoughts [Re: wheelsup68dart] #380963
07/24/09 11:25 AM
07/24/09 11:25 AM
NC
440Jim Offline
440Jim  Offline
NC
Without a delay box, all you have to do is time yourself with your brain to cut a light. That is what all the no-box and footbrake racers have to do. A slow car can't be made to react quicker by the driver because that would require seeing the light before it came on.
Or you could mechanically setup your car to react 0.500 (like all the no-box cars do), and when you race Super Pro, put the box back in with the appropriate delay (ie if you put .110 in now, put .010 in with the car setup for .500 instead of .400. The box is adjusting the final/total reaction time you see on the timeslip. Rollout is geometry, not time.
The bottom line is you can do it, it is just harder without a delay box. And that is the delay box advantage, difficulty not "possible or not"
I agree this is a fun class, and I hope everybody realizes that. My points are intended to get more cars to enter by giving them a chance to cut the same light as the next racer. And more bracket cars can cut 0.500 than 0.400.
Page 4 of 4 1 2 3 4
