You Guys Are Killing Me With This Shimmin RockersThing #378154
07/17/09 02:26 PM
07/17/09 02:26 PM
NE Ohio
71 FJ6 Charger Offline OP
NE Ohio
I have a stock 71 383 HP motor,the 346's on it are milled .030,and I'm using a .020 steel gasket.
I am using the factory cam(for now),and all the factory rockers,etc. After reading some posts on here,I am uncertain if I have to do this "shim the rockers" thing.
I did speak to Dave at Hughes,and from what I gathered(unless I'm a retard,still),unless the base circle of the cam is different than factory,he says,"why would you need to shim the rockers?". He says that there is a major common misconception for the reasons for doing this.
C'mon guys,my turn,enlighten me. I only want to do this once!
DO I NEED TO DO THIS?
Pleeeaaase,helpful and positve posts only if you could. I am sure youre all sick of hearing about it,just once more and I'll never speaks it's name again!
'71 383HP FJ6 Charger SE
Re: You Guys Are Killing Me With This Shimmin RockersThing [Re: 71 FJ6 Charger] #378155
07/17/09 02:45 PM
07/17/09 02:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Shims go between the ROCKER SHAFT AND THE ROCKER STAND (head) , when you deck a block or heads are you CUTTING THE ROCKER STANDS ????
If the answer is NO then why would a person shim the rocker shafts to make up for decking the heads and block ? Why , because they are a
And I think you misunderstood Hughes or he misspoke , changing the base circle of the cam is NOT changing rocker to valve tip geometry , again , the base circle change does not change the height of your rocker stands so it will NOT effect rocker to valve tip contact. the fix there is a LONGER PUSHROD.
If your rocker to valve tip geometry were off and required a LOWER rocker stand postion to correct it the same line of thinking as ADDING shim under the shaft would be to just run a SHORTER pushrod ? NO , you would have to MACHINE the rocker stand shorter.
What you have done MAY require a SHORTER PUSHROD , PERIOD , END OF STORY .
MP sells ADJUSTABLE length pushrods , why , to FIX the above scenerios , except for lowering the shaft ....
Re: You Guys Are Killing Me With This Shimmin RockersThing [Re: 71 FJ6 Charger] #378156
07/17/09 02:46 PM
07/17/09 02:46 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Bring the engine to TDC of #1.
Pull off the drivers valve cover and remove the rockershaft assembly. Strip off all the rockers except for #1 int and ex.
Reinstall shaft and finger tighten the adjacent hold down bolts until any pushrod lash is gone.
Lay a straightedge on the valve cover rail and lightly scribe a line on the 2 pushrods.
Tighten the bolts down completely and rescribe.
Remove the rocker shaft and measure the distance, thats your actual lifter preload.
That will tell you if your pushrods are the right length.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: You Guys Are Killing Me With This Shimmin RockersThing [Re: 71 FJ6 Charger] #378157
07/17/09 02:46 PM
07/17/09 02:46 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
appearently to change the rocker arm geometery. Side to side trying to keep it on the stem tip.
Agree with Dave, why would you?
Re: You Guys Are Killing Me With This Shimmin RockersThing [Re: 71 FJ6 Charger] #378158
07/17/09 02:47 PM
07/17/09 02:47 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
YOU DO NOT NEED SHIMS. Is that good enough for you?
Re: You Guys Are Killing Me With This Shimmin RockersThing [Re: mark7171] #378159
07/17/09 02:50 PM
07/17/09 02:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That's a different shim and they doesn't effect the rocker to valve tip geometry either , those center the tip on the stem .
Re: You Guys Are Killing Me With This Shimmin RockersThing [Re: stumpy] #378160
07/17/09 02:53 PM
07/17/09 02:53 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Short, sweet, and to the point. No you will not need a shim band aide.
Also listen to Dave and Kevin at Hughes, they have forgotten more than most here will ever know or learn.
Re: You Guys Are Killing Me With This Shimmin RockersThing [Re: MoparforLife] #378161
07/17/09 03:06 PM
07/17/09 03:06 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Only dealing with small blocks Ive never had to shim anything, but then again why do they make shims if there is no real world use for them?
This is sorta like the lash cap issue it seems, some use them some dont...some say there is never a need but they still make them.
But isnt a lash cap also a shim of a sort?
Its pretty simple to know how and where your rocker tip needs to be on the valve so I say do what you got to do it make things correct.
Re: You Guys Are Killing Me With This Shimmin RockersThing [Re: stumpy] #378162
07/17/09 03:19 PM
07/17/09 03:19 PM
NE Ohio
NE Ohio
THANK YOU
Re: You Guys Are Killing Me With This Shimmin RockersThing [Re: 71 FJ6 Charger] #378163
07/17/09 03:35 PM
07/17/09 03:35 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Lotso fun. I would only point out that you should be sure to use TDC of #1 cyl FIRING stroke.
Re: You Guys Are Killing Me With This Shimmin RockersThing [Re: quick77rt ] #378164
07/17/09 03:56 PM
07/17/09 03:56 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
yes, a lash cap effectively lengthens the valve stem, so does sunken valves, or running longer valves. if these instances occur, you may need to shim up the rocker arm shaft to correct the valvtrain geometry's relationship between the shaft and the end of the rocker to minimize side loading on the guide (which will cause excessive guide wear and valve stem wear).
if your problem is too much preload, you need shorter pushrods.
2017 Grand Cherokee Overland
Re: You Guys Are Killing Me With This Shimmin RockersThing [Re: CJK440] #378165
07/17/09 03:57 PM
07/17/09 03:57 PM
Upper Midwest
Upper Midwest
Just because there may or may not be exactly the preload you are looking for it can vary slightly as there is a H of alot of forgiveness built into the hydraulic valve lifter. Which in the case of street driven engines leaves a lot of room with out fear of damage. Personally I have taken up to .070 off heads and still had plenty of plunger travel. Granted that is pushing it but .030 - .040 will under most conditions be no problem.
Re: You Guys Are Killing Me With This Shimmin RockersTh [Re: MoparforLife] #378166
07/17/09 05:22 PM
07/17/09 05:22 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Again with this???
Re: You Guys Are Killing Me With This Shimmin RockersTh [Re: 64Post] #378167
07/17/09 06:26 PM
07/17/09 06:26 PM
NE Ohio
NE Ohio
Alright guys,it ends here. I'll bother you no more about it. I'm boltin' 'em on,no shims. I will check pre-load,etc to make sure of things.
Thanks all!
Re: You Guys Are Killing Me With This Shimmin RockersTh [Re: 71 FJ6 Charger] #378168
07/17/09 07:35 PM
07/17/09 07:35 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Thanks all!
Don't stop on my account. We're all here to learn. Some things have to be in harder than others...
This internetS thing sure is entertaining though...
Here's my take on the geometry issue and, generally, just about everything else. If your stem-rocker contact is poor it usually means your valves are sunk from a crappy/incorrect/short-cutted valve job. You could have a bad rocker or two, but that is usually not the case. The seats ought to be replaced and recut to correct the issue. Shimming the shafts are a band aid. Yes, an incorrect contact pattern will wear the guides faster, but so what? The rest of the head is crap anyway. If you're not conscientious enough to do it correctly at the basic level, then why bother sweating other minor issues? Right...?
Re: You Guys Are Killing Me With This Shimmin RockersThing [Re: mark7171] #378169
07/17/09 08:28 PM
07/17/09 08:28 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
This is one for my Yahoo Moparts file.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: You Guys Are Killing Me With This Shimmin RockersThing [Re: Rug_Trucker] #378170
07/17/09 09:05 PM
07/17/09 09:05 PM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
isn't the ideas to have the rocker tip center on the valve stem hence the needs for the shim when you shave the head too much?
Re: You Guys Are Killing Me With This Shimmin RockersThing [Re: 71 FJ6 Charger] #378171
07/17/09 09:11 PM
07/17/09 09:11 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
If you are using stock rockers and something less than a .500" lift cam, shimming the shafts is a big waste of time, UNLESS you are encountering valve float from pumped up lifters.
I had a small block that after a rebuild with stock rockers and the block and deck milled, would not rev over 4500 rpm. Turned out the lifters were pumping up at that rpm and causing the valves to hang open. UNDER THOSE CIRCUMSTANCES, I would shim the rocker shafts, OR run adjustable rocker arms.
Shimming the shafts is an old NHRA Stocker racer trick back when they were forced to use stock rockers (mostly used on stamped steel, non adjustable rockers and pushrods.) It would help them get a few more RPM out of the motor by lessening the chance the lifters would pump up and cause valve float.
Re: You Guys Are Killing Me With This Shimmin RockersThing [Re: BigTerry] #378172
07/17/09 09:17 PM
07/17/09 09:17 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
How does shaving the head effect valve to rocker relationship?... Valve stem height effects it & there is a specicfied height for them... The distance from the C/L of the rocker pivot to the point it contacts the valve effects it... But milling the head or deck surface doesn't... Again I'll post this picture which shows what shimming the rocker shaft effectively does...
Re: You Guys Are Killing Me With This Shimmin RockersTh [Re: BigTerry] #378173
07/17/09 09:52 PM
07/17/09 09:52 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Noooooo !!!
