Re: Reputable wheel restoration shop wanted.
[Re: Hardcharger65]
#377611
07/16/09 08:38 PM
07/16/09 08:38 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Try Moparts member Curt McKim (mcwheels). He may be able to help. 515-685-3397
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: 318 Stroker]
#377618
07/16/09 11:06 PM
07/16/09 11:06 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
Yes Ryan owns the Super Blue 72 340 Demon with the Spyders. It's usually his close friend "RM Mobarn" that does the actual pic posting of Ryan's Demon with the Spyders.
Excellent. Hardcharger65 just search Spyder and username RM Mobarn for two years. I guarentee he has posted where he got his rechrome and widened at. Please post the link here when you find it.
[Re: anlauto]
#377619
07/17/09 12:02 AM
07/17/09 12:02 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Steel welded to aluminum ? Are you sure about that?
Sounds right, there were a few wheels made like that. They had steel inserts cast into the aluminum center, so they could be welded into the steel outer...
[Re: Hardcharger65]
#377623
07/18/09 12:50 AM
07/18/09 12:50 AM
autoxcuda
So Cal
Yes i did but that was just to find out wheel size and backspacing on that Blue Demon not for the restoration of the wheels themselves, thanks for everyones input .
Could you post your findings on that thread so others can see it. Others are interested in rechroming and widening Spyders if we could get our hands on some.
