HHR fan, whats all needed?? #377556
07/16/09 07:27 PM
07/16/09 07:27 PM
racine,wi
70gtx1 Offline OP
70gtx1  Offline OP
racine,wi
After hearing all the rave of this fan, Im finally gonna ty it out. Im runnig 2 perma cool fans with no shroud, that are rated at 1200cfm a piece, so im sure i would see a temperature drop with the HHr fan. My question is, what else do I need to run it? Do I need the matching relay and connecter to run it? Or can I use any relay? If so, how many amp relay does everybody use? Im'm running an upgraded 220amp alternator, so power is not a problem.
Post deleted by Defbob [Re: 70gtx1] #377557
07/16/09 07:57 PM
07/16/09 07:57 PM
Re: HHR fan, whats all needed?? #377558
07/16/09 09:57 PM
07/16/09 09:57 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Only thing I need to run one is space, and I don't have it
Those fans are nice, but just too thick for my application. With 220 amps, you could run 3 or 4
codfish
Re: HHR fan, whats all needed?? [Re: codfish] #377559
07/16/09 10:07 PM
07/16/09 10:07 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
I thinned my HHR fan out about as much as you possibly can to squeeze it in the BBR.
Although the HHR fan is not overly deep at 4", the BBR needed it to be thinner to fit in between the water pump snout and the radiator. I test fit it and while it *did* fit, the back of the shroud behind the motor was just touching the water pump pulley.
So I did what any good gearhead does. I took a brand new part and started taking it apart. Upon close inspection I decided that the plastic area behind the motor could safely be removed. Removing this plastic (outlined in yellow) will give a net gain of 1/2". The back of the motor only sticks out 1/4" past the lip marked with a red arrow.
Next thing to be removed is the little locating tabs. They are 1/8" tall. Grind these off flush.
It's very cozy in there, but it fits and keeps the temps down. This is a 11.6:1 545" motor with a 19x27 radiator.
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
