Valve springs #376856
07/16/09 12:51 AM
07/16/09 12:51 AM
Wayne, Michigan USA
K
KryslerKid Offline OP
K
Wayne, Michigan USA
Will a factory set of 915 HP heads with their factory springs work with a .509 cam? thnx
Re: Valve springs [Re: KryslerKid] #376857
07/16/09 02:01 AM
07/16/09 02:01 AM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
no
Re: Valve springs [Re: Baxter61] #376858
07/16/09 02:05 AM
07/16/09 02:05 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
not even a consideration
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: Valve springs [Re: R70RUNNER] #376859
07/16/09 03:09 AM
07/16/09 03:09 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Only if you intend to turn that 509 cam into a 309 cam.
No chance.
Re: Valve springs [Re: RobX4406] #376860
07/16/09 06:56 AM
07/16/09 06:56 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Not unless you like what can happen as the results of coil bind.
Re: Valve springs [Re: MoparforLife] #376861
07/16/09 08:31 AM
07/16/09 08:31 AM
scratchnfotraction Offline
those pistons are "used"
Re: Valve springs [Re: scratchnfotraction] #376862
07/16/09 08:38 AM
07/16/09 08:38 AM
Upper Midwest
Upper Midwest
and abused - seriously they are out of a 360 using stock springs with 484 lift resulting in coil bind. The rotators had not been removed and a longer spring used either. After measuring the with a longer regular non rotator spring it would have been real touch and go anyway but the rotators were the straw that broke the camels back. It also cost a sleeve, head, cam, a couple of rods and a crank that could be salvaged surprisingly with a .010 cut.
Re: Valve springs [Re: R70RUNNER] #376863
07/16/09 10:49 AM
07/16/09 10:49 AM
Wayne, Michigan USA
K
K
Wayne, Michigan USA
What's a good set of springs to order for these heads? Their 915HP's, virgin, have been cleaned up, going on 440 six pack, 509MP cam, .030 trw domed,new Elgin factory length push rods, new Mopar factory style rockers, new CompCams rocker shafts, Rhodes lifters, and I believe they're the stock valves on the heads... my old heads seemed to have held up okay, 906's, but had a bent/stuck valve and had these on the shelf. thnx
Re: Valve springs [Re: KryslerKid] #376864
07/16/09 11:25 AM
07/16/09 11:25 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run Comp springs retainers amd keepers.Its a good idea to upgrade to them.The retainers usually arent a problem but why trust 40 year old keepers.Im running a .588 lift with my Comps solid cam.You will probally need new seals also.Rocky
Chrysler Firepower
Re: Valve springs [Re: KryslerKid] #376865
07/16/09 02:20 PM
07/16/09 02:20 PM
northeast texas
strokin73cuda Offline
northeast texas
"Thier 915HP's virgin" You will definately want to make sure they have the hardened seats in them or this new fuel "will" hammer them out eventually.
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
Re: Valve springs [Re: strokin73cuda] #376866
07/16/09 03:09 PM
07/16/09 03:09 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You have a PM
Stan
