Challenger ignition lock troubles...HELP! #376419
07/15/09 05:19 PM
07/15/09 05:19 PM
Heart of Ohio
4boxers4 Offline OP
4boxers4  Offline OP
Heart of Ohio
Swapping out the ignition switch and lock on my 71 Challenger and everything was going well...put the switch in and locking bar with the lock. Screwed in the lock plate then turned the key and it was good. When I turned the key backwards,it would not go all the way back to where i could pull the key out again. In addition, I could not move the key backwards to the accessory position either. Checked to make sure the install was done with the switch in the off position but I am stymied. I put the old lock and switch back in and voila'! I have the same problem but I didn't have it before the swap began! WTH? I looked at the locking bar and it appears to be in the correct location but now I am confused. Anyone care to throw experience or advice at this, please? It would be greatly appreciated!!
Persistance is omnipotent Durability Engineer, Chair and Couch division...
Re: Challenger ignition lock troubles...HELP! [Re: 4boxers4] #376420
07/15/09 05:42 PM
07/15/09 05:42 PM
NJ
Annie Offline
Annie  Offline
NJ
Just a guess shift interlock linkage?
Re: Challenger ignition lock troubles...HELP! [Re: Annie] #376421
07/15/09 06:53 PM
07/15/09 06:53 PM
TX , NJ , FL
W
WINGCARS_6970 Offline
W
TX , NJ , FL
Just curious does the steering wheel still lock
1969 Daytona 440 L9B410772 1970 Coronet 500 383 Presently owned 1970 Superbird 440 U 166242 1970 Superbird 440 U 174597 1970 Superbird 440-6 V 179697 1970 Coronet RT 440 U 224126 1968 Road Runner 426 J 134509 1970 Daytona Replica 318 G 178701
Re: Challenger ignition lock troubles...HELP! [Re: WINGCARS_6970] #376422
07/15/09 08:25 PM
07/15/09 08:25 PM
Heart of Ohio
4boxers4 Offline OP
4boxers4  Offline OP
Heart of Ohio
Not sure if we are talking about the same thing but maybe yes...shift interlock linkage may be what I am referring to as the piece riding between the ignition key tumbler and the ignition switch. This appears to be in the same condition as in the photos from the service manual.
Don't know about the steering wheel turning as there are too many components not yet installed back on to the column to add the steering wheel. Maybe I need to add pics to help...
Re: Challenger ignition lock troubles...HELP! [Re: 4boxers4] #376423
07/15/09 08:54 PM
07/15/09 08:54 PM
Heart of Ohio
4boxers4 Offline OP
4boxers4  Offline OP
Heart of Ohio
I think I figured it out when I went to get a picture. The lever and pin assy was stuck.
