My 70 Charger RT 4speed car came with power drum brakes. The engine (512ci)has a Hughes cam 587 lift with 260 duration with 10.5 compression.
For the front I have installed Cordoba disc brakes with E body calipers.
On the rear I have installed a TSM disc brake kit which has Ford Explorer discs and calipers from a 77 GM vehicle.....I know
I purchased a remanufactured power brake booster and master cylinder for a 70 Charger with disc brakes.
I am trying to fix a slight leak coming from the bottom of the brake junction block that is mounted on the frame at the front of the car and from the brake line at the passenger side rear caliper.
I have bled the brakes twice and the pedal only comes of the floor about 3 inches and I feel the pedal pressure could also be firmer.
What could be causing the pedal to only come off the floor a couple of inches?
