rear axel width chart ??? #375764
07/14/09 11:55 PM
07/14/09 11:55 PM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hin
where do i find the rear axel width chart ??
thank you !
Re: rear axel width chart ??? [Re: calrobb2000] #375765
07/14/09 11:57 PM
07/14/09 11:57 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: rear axel width chart ??? [Re: HealthServices] #375766
07/15/09 10:13 AM
07/15/09 10:13 AM
Keep in mind that these charts are mostly a guide and the numbers do vary as tolerance wasn't exactly a science. Measure the rear you plan to use before sticking it in to make sure especially if clearance will be tight.
Re: rear axel width chart ??? [Re: calrobb2000] #375767
07/15/09 01:44 PM
07/15/09 01:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's the link to the archive info:
http://www.moparts.org/Tech/Archive/axle/16.html
Production variations aren't sufficient to confuse the correct parts.
