Re: OEM Carter AVS tuning issue
[Re: RapidRobert]
#375695
07/15/09 11:55 PM
07/15/09 11:55 PM
Posts: 10,218 Someplace you aren't
SomeCarGuy
I took the idle screws out and sprayed in the starting fluid. I couldn't really tell if it made any difference. I held my hand over the choke area nd if I got a good seal it raised the RPM so I went from 2 turns out to 2 1/2. Better but same test= same results. I ended up at 3 1/2 turns. That would seem to indicate a vaccum leak. The idle now smells rich but it holds steady and returns well. I took a spin and it flet much better. I forgot to tune the secondaries , that might make a differnce at speed but the idle mixture made it much better overall. I was able to turn the idle speed screw quite a bit after richening the mix, now holding pretty solid at 850. I still seem to have the off idle stumble some. I think there is something in that circuit as it isn't a constant problem. Will almost bog enough to die in first sometimes.
[Re: SomeCarGuy]
#375698
07/16/09 12:51 AM
07/16/09 12:51 AM
RapidRobert
You might tighten up the air door several more turns just to take the secondaries completely out of the picture as this(appears) to be a pri system problem or even removing the secondary link so the secondary throttles dont even open(kind of brainstorming on that) but anything to eliminate/narrow down the problem but keepin it simple I would lean the idle mix screws a bit & mainly concentrate on the AP system especially after what you did so far made a dramatic improvement. I'd check for immediate tip in, that the plunger lever is in the hole furthest from the fulcrum then readjust the plunger to max height & possible enlarging the shooter nozzles
[Re: SomeCarGuy]
#375700
07/16/09 01:07 AM
07/16/09 01:07 AM
RapidRobert
yeah but didn't you say that the idle mix threads on the other one were cross threaded or something (it sounded bad )
[Re: SomeCarGuy]
#375708
07/16/09 09:44 PM
07/16/09 09:44 PM
RapidRobert
I'd continue to search for why there's no squirt on tip in, maybe check the brass weight under the shooter and the gasket for starters. Since you have several shooters to play with you might drill one a few thou larger since that is the restriction AFTER tip in is reestablished
[Re: SomeCarGuy]
#375712
07/17/09 01:24 PM
07/17/09 01:24 PM
SomeCarGuy
Installed the needle in the accel pump circuit- Noticed it still had a stumble off idle at first. Seemed to get better after running awhile but it was nearly fully warmed when i took off from the house so...? Car is running smoothly down the road. WOT doesn't have the bog the 750 Eddy AFB had BUT it doesn't pull near as hard either. I checked the WOT adjustment and with some weight on the pedal it is about 1/16th short of full open. I would like to check with a helper tonight and see what I think, the weights are hard to wedge and I don't have the old 2x4 I used to use as a dead man anymore. Drone seems less with this carb. Maybe harmonics changed with the smaller butterfly's. Idle sounds wicked now. I don't understand why the Carter does this and the Eddy was smooth. Anybody have any ideas why that would be? I will be testing going back to the top hole for a bigger pump shot. Also will try a K&N filter in the current breather(open) and then with a K&N lid. Might be an improvement if the carb doesn't like the drop base putting a restriction close to it with the solid lid. Will also try different idle mixes, hopefully I will find my vac gauge. This 4966 doesn't feel as crisp as the other one I tried that had the boogered up stuff. It had the one off size rod, makes me think this one could use some tuning but it is hard to go off a cobble carb as a guide. It seemed to really jump on throttle movement more than this 4966 does. Thanks for all the help!
