'70 E Body Wiper Switch Connections Rallye Dash ?? #375495
07/14/09 09:02 PM
07/14/09 09:02 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
I think I remember correctly that one prong on the back of a 3 speed '70 E body rallye dash wiper switch is left exposed/nothing plugs into it.But is there only one way that the connections from the main harness plug into the wiper switch?Could someone post picture of the correct connections?Is it a one piece plug or 2 piece?I was thinking mine had 2 seperate plug ins?
Re: '70 E Body Wiper Switch Connections Rallye Dash ?? [Re: 44D6PAKCUDA] #375496
07/15/09 02:13 AM
07/15/09 02:13 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
If I read the wiring diagram correctly.
The 2 & 3 speed switches have a different pin layout, the wiring is the same.
2-speed
V3-18BR* goes to pin F1
V4-18R goes to pin A
3-speed
V3-18BR* goes to pin A
V4-18R goes to pin F1
3 Speed switch.
Re: '70 E Body Wiper Switch Connections Rallye Dash ?? [Re: Snoopy] #375497
07/15/09 02:25 AM
07/15/09 02:25 AM
Snoopy Offline
Snoopy  Offline
Diagram
Re: '70 E Body Wiper Switch Connections Rallye Dash ?? [Re: Snoopy] #375498
07/15/09 06:40 AM
07/15/09 06:40 AM
Thanks for the pics Snoopy.Is it possible to have the small 2 prong? harness plugged in wrong?And is the top prong,as shown in picture,always left "empty"?
Re: '70 E Body Wiper Switch Connections Rallye Dash ?? [Re: 44D6PAKCUDA] #375499
07/15/09 12:03 PM
07/15/09 12:03 PM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
They only plug in one way.
Re: '70 E Body Wiper Switch Connections Rallye Dash ?? [Re: BJohnson] #375500
07/15/09 12:26 PM
07/15/09 12:26 PM
cataclysm80 Offline
cataclysm80  Offline
That's a good picture.
Tav
Re: '70 E Body Wiper Switch Connections Rallye Dash ?? *DELETED* [Re: cataclysm80] #375501
07/15/09 02:06 PM
07/15/09 02:06 PM
Snoopy Offline
Snoopy  Offline
Re: '70 E Body Wiper Switch Connections Rallye Dash ?? [Re: Snoopy] #375502
07/15/09 06:47 PM
07/15/09 06:47 PM
wi
crscuda Offline
crscuda  Offline
wi
Hate to "butin" but, when changing from a 2 speed to a 3 speed wiper motor is it plug and play. I mean install the 3 speed motor, transmission and switch and it will work?? Anything else?
