Re: painters need help
[Re: paul69cuda]
#375181
07/14/09 05:25 PM
07/14/09 05:25 PM
Posts: 624 Modesto CA
BFASTER
Modesto CA
I don't see why not. It's not recommended using different products but it shouldn't be a problem. I've done it before. Make sure you follow the directions on the PPG sealer as far as dry times.
1969 Dodge Super Bee Hardtop
2007 Nissan Altima 3.5SE
[Re: Dougsmopars]
#375185
07/14/09 07:48 PM
07/14/09 07:48 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
I agree, don't be cheap on paint...50$ for Nason is cheap, 50$ for a gal of sherwin is another thing !! but with sherwin you need stabaliser AND reducer......Been painting for years with PPG and wouldn't change..Sherwin is my second favorite..
ALWAYS SPRAY 3 COATS OF BASE !! will keep you out of trouble, as mentioned by Dougsmopar, 2 quarts is enough, strongly recommend a good clear like Sherwin CC930 or Dupont 7900 both with medium activator
Hope advice helps
Daniel
