Re: Indy head oil restriction
[Re: Dodgem]
#374937
07/14/09 02:09 PM
07/14/09 02:09 PM
Posts: 43,321 Bend,OR USA
Cab_Burge
I have used a short piece of welding rod, 080 diameter, and bent it into a L shape it so it would stay in the head under the fitting, works good so far ![](/ubbthreads/images/graemlins/thumbs.gif) I have built several world blocks, the use a .040 restictor in the block to oil the rockers, they oil the rocker full time just like the indy set up does ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Lil Demon]
#374938
07/14/09 02:16 PM
07/14/09 02:16 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Hello The stock Y/T fitting & block that screws into the back of the block that comes with the standard Indy oiling Line kit can be modified. I simply drilled and tapped the NPT end of the fitting (the end that screws in the block) which is a 3/8 NPT IIRC. Anyways, just pick up the right tap, and drill for the tap, and install standard Holley jets. I used a .070 with no problems at all (you could probably run even a .060). I ran this setup on 3 diff engines too. One was a 493 RB engine with a set of 440-1, and Indy/Dove rockers. Later I upgraded the heads to CNC ported units that used the Jesel Paired rocker system. Then a few years later, I built a new Indy maxx block engine also using the Jesel system. Never had a valve train issue, matter of fact It went whole seasons before It ever need a lash adjustment, then it was never really off much. I turned these large 560+ inch engines to 8K in a few cases. You just dont need gobs of oil up top with a drag racer. I bet you could pull the valve cover, pour a quart of oil all over the valve train and make pass after pass doing this without ever hurting anything. I will add this, make sure you have a good oiling system. These full time oiling kits will put loads of oil up top, (why it needs to be restricted) I would say a 8 qt pan, would be minimal for pan capacity.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#374939
07/14/09 03:07 PM
07/14/09 03:07 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
10 quart ss pan, dual lines off dual line swinging pick up with milidon pump and cap and adjustable pressure relief spring thats set to 70 lb. Not sure I understand? mine is about 1/8 pipe thread into head??? I'll have a better look when I pull them off. Block is lifter bore bushed with .050 or so holes. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Dodgem]
#374940
07/14/09 04:24 PM
07/14/09 04:24 PM
Posts: 7 AB Canada
Demon Guy
AB Canada
Thats exactly what I've done to two sets of heads, works good, still lots of oil up top. Drilled hole to 1/16"
71 Demon 451 SR All Motor
Chassis car 2475 w/driver
Best ET 9.08 @ 150.05, 4787 Corrected Alt
[Re: Bob_Coomer]
#374942
07/14/09 07:40 PM
07/14/09 07:40 PM
Dodgem
Ontario, Canada
Im not talking about the head at all, again the Y fitting that screws in the back of the block. They are two on standard blocks, I cant remember which one the y block screws into.. 50% chance its 1/4 NPT, or 3/8 NPT. I guess you could restrict it at both heads, if the fittings have enough meat. But thats twice the work, and twice the fittings jets to use and change. Restrict it out of the block. .070 will feed both heads just fine.
Oh I see what you mean Bob. I'll look it over have the heads off now as I had oil coming out of the back of one head. looks like the tang that goes up valley tray at the back was leaking. My O rings are good and stayed in place so I think I'll get a .032 gasket (if I can find one) and goop with a different sealer and back together with some type of oil restrictor. Thanks Guys.
[Re: Dodgem]
#374943
07/16/09 12:49 PM
07/16/09 12:49 PM
Dodgem
Ontario, Canada
Does anyone know the thread size on holley jets?? Looks like i can drill and tap the fitting at the head and there is enough room inside for a jet and more?? Thanks again
[Re: Bob_Coomer]
#374945
07/16/09 01:36 PM
07/16/09 01:36 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Im almost 100% sure they are 1/4 x 32 thread
The thread is 1/4x32.If you can't find a 32 tap use a standard 28 thread the jet will screw in tight. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Dodgem]
#374947
07/23/09 10:58 AM
07/23/09 10:58 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I need to restrict the oil going to my spray bar valve covers. In hopes that it will help my oil pressure(oil pressure is a little lower than I feel safe with). I think maybe the easiest way will be to do it at the base of the t-fitting coming out of the block. Am I correct on this? Dodgem, I was thinking of shimming the spring in the oil pump also but like the idea of the adjustable pressure relief like you mention you have on yours. I have the Indy pump could you use one of those on this pump,if so where do you get them? THANKS!!!!
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#374948
07/23/09 12:37 PM
07/23/09 12:37 PM
MRMOPAR622
Sweet Home Alabama
Just went out to the shop to pull off my t-fitting to the spray bar valve covers. The top of the fitting has a reducer that takes the hole size down to 9/64 the line that goes up and splits into 2 lines to fed the spray bar valve covers has a 3/32 hole in the fittings that screws down onto the 9/64 hole coming out of the block. It looks like it is already restricted enought. Is there any need to still put a pipe plug in and drill out to 11/64 at the base of the fitting with the restriction it already has? THANKS!!!!!
