Re: Alternator help
[Re: 572B1]
#373697
07/13/09 11:39 AM
07/13/09 11:39 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
IMO 60 amp will be border line for your setup. Most of the Ultra/Super Mini alt are about 50 amps. Personal experience tells me these dont do a great job, period. I used a larger GM 1 wire alt with the DMI setup, but which took some notching of the brackets etc. The alt I used was from a Mid 90's Pontiac Grand Am (small) that I had converted to a one wire setup and was smaller than the standard GM unit, but not as small as the Mini's. Out put was 70-80 amps, and worked very well for me. I had under $50 in this alt.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: Alternator help
[Re: 572B1]
#373699
07/13/09 06:53 PM
07/13/09 06:53 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
http://chucker54.stores.yahoo.net/delialbrpk.htmlI got this one 120 amp charges like a bear at low rpms so no need for a generator any more 250 gal pump, msd, electric fan and water pump. MANCINI - B/RB Wedge Alternator / Bracket Kit 120 amp Alternator Note: On 72-Up B-Body and A Body applications may need to alter framerail for clearance. $249.95 MRE6655 don't know if it will fit yours
Re: Alternator help
[Re: 572B1]
#373700
07/13/09 06:54 PM
07/13/09 06:54 PM
Bob_Coomer
Rock Springs
Here is a crappy picture of the alt i was speaking of. You can use this size alt with the DMI brackets etc. The main bracket that picks up the timing cover bolts (one is 3/8 other is 5/16) on that setup required some notching so the case would have extra belt travel. Im almost 100% you can get these alt in 200 amp versions... I will try to dig up another pic if it will help. BTW this setup looks like crap, but I turned this engine 7500+ and never once threw a belt...a few 8K blasts I might add too. ![](http://i93.photobucket.com/albums/l45/The_Dakota_Kid/IM002288.jpg)
Re: Alternator help
[Re: 572B1]
#373702
07/13/09 07:03 PM
07/13/09 07:03 PM
Posts: 2,175 Duloc
The Shadow
Duloc
Thanks Bob, I would like a 120 amp alternator, but the dmi bracket only fits mini style alternators.
I originaly was going to by a msd unit, but they don't sound real reliable on a street car.
I'm running a 120amp denso from a ram with a dmi low mount alt bracket. I had to fab up a slotted arm to get it to work but none of the mini's put out enough juice. I really wanted to to convert it to a gm 1 wire alt but all I could find locally was a 100amp.
![](/ubbthreads/images/graemlins/beer.gif)
