Enourmous hood scoop pan
#372697
07/11/09 07:38 PM
07/11/09 07:38 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I've been putting off sealing my 6pak hood for 2 years because the carb sits above the hood line, I thought it would be hard to do but I mocked it up with cardboard and it turned out to work fine with a flat piece of aluminum. Thanks for the awesome piece of aluminum by the way MrPbody! I will eventually bond this to the bottom of the hood with a hole in it for an air cleaner so I can run it on the track the same way as the street but hopefully next saturday I'm gonna track test this huge pan. ![](/ubbthreads/images/graemlins/grin.gif) I modified the return spring slightly so it won't hang up on the pan at full throttle. I also made a bracket to hold it down to the carb at speed, and I'll be testing jets with the pan too. I'll let you know how it goes!
Re: Enourmous hood scoop pan
[Re: ProSport]
#372698
07/11/09 07:44 PM
07/11/09 07:44 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I am just in the process of making one for my Dart, the pan is even larger than yours due to the size of the hemi scoop. What type of foam have you used. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: ProSport]
#372702
07/11/09 11:32 PM
07/11/09 11:32 PM
Posts: 1,532 off the grid
340B5
off the grid
Mine was worth a tenth and a little over 1 mph. In the cooler night air it really picks up around 1000'.
Yeah, it's got a smallblock.
[Re: S/ST 3040]
#372704
07/12/09 12:05 AM
07/12/09 12:05 AM
340B5
off the grid
.10 from a non sealed six pack style scoop.
[Re: ademon]
#372710
07/12/09 12:47 PM
07/12/09 12:47 PM
340B5
off the grid
[image] ![](http://i620.photobucket.com/albums/tt285/B5Blue/PICT0002-1.jpg) [/image] [image] ![](http://i620.photobucket.com/albums/tt285/B5Blue/PICT0003.jpg) [/image] [image] ![](http://i620.photobucket.com/albums/tt285/B5Blue/PICT0005-2.jpg) [/image] --------------------------------------------------Duct tape is kinda ugly, but it keeps the foam (pipe insulation) on. The silicone adhesive kept comming loose. Aluminum measures .077 thick.
[Re: Jeremiah]
#372712
07/12/09 10:09 PM
07/12/09 10:09 PM
ProSport
Akron, Ohio
Did I mention I love your "new" car?
Thanks, after installing a different motor, tranny, wheels/tires and every nut bolt and bracket on the car I'm finally starting to enjoy it. ![](/ubbthreads/images/graemlins/smile.gif)
[Re: MR_P_BODY]
#372714
07/13/09 12:25 AM
07/13/09 12:25 AM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
gotta make me one too, already have the cardboard template, just gota find the alum. stock
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: Gierhed]
#372715
07/13/09 08:16 PM
07/13/09 08:16 PM
Posts: 4,085 Mo.
racerx
Mo.
Looks like it will work good. On my sixpak hood I glued a piece of lexan to the bottom of the hood then used a standard Moroso pan and made a hole in the lexan accordingly.
Have a Pic. ![](/ubbthreads/images/graemlins/scope.gif)
[Re: racerx]
#372716
07/13/09 11:44 PM
07/13/09 11:44 PM
Posts: 2,864 IN
Irun5snd8th
IN
Bob is one of those guys thats always tinkerin and trying to build a better mousetrap.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
