Re: Fast 3.23 or higher geared combinations
[Re: MadMez]
#371110
07/09/09 05:01 PM
07/09/09 05:01 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Not a 10 second ride, but a member on here (forphorty) has a 68 Satellite with a more or less stock bottom end 440, Id guess compression at around 9 to 1, basically stock 452s, 292 Comp Hyd cam, SD intake, 750 DP, 9.5 inch Dynamic,(Had a GER in it at the time of the 12.30s) with 3.23s that has been 12.30s. Im sure with a little head work it go in the high 11's. He might chime in, but the motor has upwards of 50K on it, I think it has more than that on it.....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#371111
07/09/09 05:15 PM
07/09/09 05:15 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I didn't have it on a track yet, so time slips are not available, but my 440 in a 383 block (438 cu inches) was a 9.5:1 unported 906s edelbrock 850 carb w/electric choke, and a comp XE275HL cam, TKO-600 and 3.21s with 28.5" tires, and it would roast the tires in first gear from a 20 mph roll...no idea what it would run in the quarter though--but with that much torque, some sticky tires, I'm sure it could have pulled off a low 13 second 1/4 mile (it's a 4200 lb truck!)
now it's a 4.56 gear'd rear, aluminum eddy heads, holley 750HP carb, and 505hp at the crank, and I HOPE it's a 12 second truck--gotta get it track legal first though--drive shaft loops, etc.
**Photobucket sucks**
[Re: MadMez]
#371112
07/09/09 05:50 PM
07/09/09 05:50 PM
Posts: 30,460 Florida STAYcation
dOOc
The village idiot's idiot
Florida STAYcation
All steel 69 Coronet ? ... low 10's ...I doubt it. I like the short-gears .... I have a 62 Belvedere with a 440 and a 2.76 gear. Based on running a Bud of mine ... the car used to run 12.60's ... now it should run 12 teens or so. Iron Manifolds, thru the muffs ...and get 17 mpg on the hwy.
[Re: Von]
#371115
07/09/09 07:22 PM
07/09/09 07:22 PM
Posts: 1,459 oklahoma
forphorty
oklahoma
hey You got it almost right Von, except 906s and had an old Torker on it for my best et. 12.35, 106, 1.69 60ft. SD intake picked up about 1 mph but no et improvement. compression is prob 8.5 i guess. TRW 2266 pistons.
[Re: RemCharger]
#371116
07/09/09 07:26 PM
07/09/09 07:26 PM
forphorty
oklahoma
Theres a member on here with a 4100lb 67 charger that runs 11.60s with a 3.23.BDS67?
I think he has stock manifolds and a stock torque convertor too.
[Re: forphorty]
#371117
07/09/09 07:54 PM
07/09/09 07:54 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Mine is nothing impressive at all...but given the combo I guess its OK...
All steel 70 Challenger in full street trim.
3,23 gears.
28" tall STREET radial tires (crappy run of the mill 255 tires).
4 speed.
Home built stock stroke 360, 9:1 CR, BONE STOCK 360 heads with factory 3 angle valve job NO PORTING, NO BLENDING, Edelbrock PERFORMER intake (not RPM), 600cfm eddy carb, small 15/82 el cheapo headers, full exhaust, lunati vodoo cam
Advertised Duration (Int/Exh): 268/276 Duration @ .050 (Int/Exh): 226/234 Gross Valve Lift (Int/Exh): .494/.513 LSA/ICL: 110/106 Valve Lash (Int/Exh): Hyd/Hyd RPM Range: 1800-6200 Includes: Cam Kit
Part Number: 60403LK
I ran 14,50
My shifting could be vastly improved though. I was very gentle not to spin them and the shifts were kinda soft too.
[Re: MadMez]
#371119
07/10/09 06:19 AM
07/10/09 06:19 AM
Posts: 2,703 Mohnton, Pa
DodgeCharger
Mohnton, Pa
The latest Mopar Action has a 69 Coronet with 3.23 gears running low tens. The details on the engine are very thin, 512 cube stroker 400 with stage VI heads and a small roller cam with an operating range of 2k to 6k rpm. The builder states the biggest mistake most guys make is overcamming.
Can you guys with fast tall geared cars let the rest of us know some details of your cars?
Tim
I'd have to see a 3.23 geared car run low 10's to believe it. Unless the car has a ton of weight stripped off of it and running nitrous.
[Re: MadMez]
#371121
07/10/09 08:01 AM
07/10/09 08:01 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
gmachinedartGT has a eddie headed roller cam stroker small block in his car with a low gear 904 and 2.94's and IIRC he runs in the 12's, even though the car is setup for autocross with 18" rims....
[Re: MadMez]
#371125
07/11/09 02:30 AM
07/11/09 02:30 AM
Posts: 4 saskatchewan canada
sthorvictor
saskatchewan canada
my times are not super fast but heres my set up.... i have a 75 plymouth duster with a 69 383 high performance, the motor was stock (running good compression on seven cylinders with number 4 at 63 psi)stock manifolds both intake and exhaust, at the time i ran with a 650 holley double pumper, slightly modded, w/ ram air 727 torqueflite trans with a stock 1600 stall and stage two shift kit, 3.23 gears open 8 1/4 diff, and the rear tires were BfGoodrich p 255/60/R15 car weight with myself 3450lbs and my time was.... 14.319 w/ 60 ft @ 2.183 and reaction .080 in the last couple weeks ive striped the 906 heads off which had a sunk in exh valve on number 4 and have fixed up a set of 452's as a summer replacement, i got the trans rebuilt as it was slipping in second and partially third, im waiting for a 2600 stall converter, and im planning on throwing on a smaller tire (my old size P225/60R15 (the tire size made a 1 second difference in my car i ran a 14.9 with an eddy and the tires when i threw on the other tires with the same carb it dropped to 16.0, then i introduced the holley, and ram air and ran the 14.3.....) soo long story short im hoping on running mid to low thirteens when i get everything buttoned up in the next couple weeks
