How far to fill master cylinder (manual brakes) #369189
07/07/09 03:54 PM
07/07/09 03:54 PM
Northern Virginia
Moparmaniacc Offline OP
Northern Virginia
How high should the fluid level be on 70 Challenger, manual drum brakes. The service manual doesn't specify. My master cylinder is the same as in the pic.
Re: How far to fill master cylinder (manual brakes) [Re: Moparmaniacc] #369190
07/07/09 04:25 PM
07/07/09 04:25 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
I allways fill them right up. Never had any trouble.
Re: How far to fill master cylinder (manual brakes) [Re: Dougsmopars] #369191
07/07/09 04:28 PM
07/07/09 04:28 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I wouldn't fill to the top unless you're going to bleed the system right away too. I keep mine between 1/2 to 3/4 full, or, about an inch from the top. unless you have a leak, you won't lose any fluid other than what gets used as the pads wear down, and the piston in the calipers extends outward, but that's not going to happen in a week either, so keep an eye on it over time, and "top off" as needed.
**Photobucket sucks**
Re: How far to fill master cylinder (manual brakes) [Re: 70Cuda383] #369192
07/07/09 05:45 PM
07/07/09 05:45 PM
Northern Virginia
Northern Virginia
I don't have any calipers but I assume as the shoes wear the same thing happens...
Thanks!
Re: How far to fill master cylinder (manual brakes) [Re: Moparmaniacc] #369193
07/07/09 06:01 PM
07/07/09 06:01 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Thanks!
actually not... the shoes have adjusters that kick out the bottom of them to compensate for wear, so that the wheel cylinders are not over extending when you hit the pedal...also, drum shoes have springs that pull the shoes back in after the pedal is released, which is why you need the adjusters at the bottom...disc brakes do not have return springs, and the piston inside the caliper stays extended, holding the pad right up against the rotor at all times, so on a 4 wheel drum system, your fluid level should NEVER drop unless you're leaking somewhere
