999 Rebuild - pics of "mysterious" washer
#368947
07/07/09 10:46 AM
07/07/09 10:46 AM
Posts: 1,488 New Mexico
74Scamp
New Mexico
Hopefully, I've remembered how to post pictures. This is the thrust washer that I cannot figure out where it goes. Can someone please help? The tranny is from a 78 Dodge Diplomat police car, and this washer does not show up on the manuals that I have. thanks everyone.
Re: 999 Rebuild - pics of "mysterious" washer
[Re: 74Scamp]
#368951
07/07/09 05:56 PM
07/07/09 05:56 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
the #2 thrust washer looks just like the #1 thrust washer and is usually a fiber washer.
those washers usually dont have a tang on them...but i am no expert.
here is a picture of that washer in place
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#368952
07/07/09 05:58 PM
07/07/09 05:58 PM
70AARcuda
las vegas
another pic of the washer i moved it so it can be seen better.
Tony
[Re: 70AARcuda]
#368954
07/08/09 09:28 AM
07/08/09 09:28 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
Yes the 2 thrust washers are a fiber type material , or plastic , his washer is what you would find in the geartrain attached to the main/outputshaft , he must have one in there or else the geartrain endplay would be in the neighborbood of .100 when max is under .030
[Re: JohnRR]
#368955
07/08/09 10:28 AM
07/08/09 10:28 AM
74Scamp
New Mexico
Thanks guys. I really appreciate the help. I would think, though, that my washer needs to go where there is a "notch" or "hole" for at least one of the tangs to fit into. The inside tang is just flat, whereas the outside tang is "bent" down (or up depending on your point of view, I guess). I think the cat got up on my work bench and moved the plastic bag I had this washer in. It was with a snap ring that I've put in already, so I'll take it apart and look in that area. I'm such a dufuss sometimes!
[Re: 74Scamp]
#368956
07/08/09 06:25 PM
07/08/09 06:25 PM
Posts: 271 MO, USA
Tom Hand
MO, USA
74, that goes in the front planetary setup. The 904 uses a smaller one and the wide ratio gear set, like the 999 should have, has a larger diameter one. You take the big snap ring off and then the planet carrier comes out and that thrust washer is between the ring and the outer drum/shell. Most good kits come with both the larger and smaller thrust washer. Tom Hand
[Re: Tom Hand]
#368959
07/09/09 10:38 PM
07/09/09 10:38 PM
Posts: 271 MO, USA
Tom Hand
MO, USA
[Re: 74Scamp]
#368960
07/20/09 08:40 PM
07/20/09 08:40 PM
Posts: 271 MO, USA
Tom Hand
MO, USA
Dave, here is one. This is basically the 904 family from 1962 until 1988 or so.
[Re: Tom Hand]
#368961
07/20/09 08:42 PM
07/20/09 08:42 PM
Posts: 271 MO, USA
Tom Hand
MO, USA
