need pics of 73-4 roadrunner front and rear sway bars #367027
07/04/09 11:11 PM
07/04/09 11:11 PM
Nashport, OH
chargers777 Offline OP
Nashport, OH
I got the bars with my 73 satellite and I am trying to figure out how they go and if I have all the parts.Will these bolt on a satellite with out welding?Who sells these bars in the aftermarket?Thanks for any help.
Re: need pics of 73-4 roadrunner front and rear sway bars [Re: chargers777] #367028
07/05/09 05:25 PM
07/05/09 05:25 PM
Nashport, OH
Nashport, OH
bump
Re: need pics of 73-4 roadrunner front and rear sway bars [Re: chargers777] #367029
07/05/09 06:02 PM
07/05/09 06:02 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Which bars do you have?
Re: need pics of 73-4 roadrunner front and rear sway bars [Re: Dcuda69] #367030
07/05/09 06:30 PM
07/05/09 06:30 PM
Nashport, OH
Nashport, OH
I have the stock bars and I need a pic to show how they are mounted and to make sure I have all the brackets I need.
Re: need pics of 73-4 roadrunner front and rear sway bars [Re: chargers777] #367031
07/06/09 07:07 PM
07/06/09 07:07 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
They should bolt on without any welding...Here's a pic of the front bar...End link is a two piece bracket that bolts to the control arm stabilizer...Center link is fastened to the K member using rubber/poly bushings...
Re: need pics of 73-4 roadrunner front and rear sway bars [Re: screamindriver] #367032
07/06/09 07:14 PM
07/06/09 07:14 PM
Harrisburg, Pa.
Harrisburg, Pa.
And a pic of the K frame with the attaching holes circled...
Re: need pics of 73-4 roadrunner front and rear sway bars [Re: screamindriver] #367033
07/06/09 07:15 PM
07/06/09 07:15 PM
Harrisburg, Pa.
Harrisburg, Pa.
And a shot of the 73-4 rear bar with the hardware..
Re: need pics of 73-4 roadrunner front and rear sway bars [Re: screamindriver] #367034
07/06/09 07:18 PM
07/06/09 07:18 PM
Harrisburg, Pa.
Harrisburg, Pa.
Here's a shot of the axle bracket in place...these reference pics are of my 73 Road Runner project FYI... ...
Re: need pics of 73-4 roadrunner front and rear sway bars [Re: screamindriver] #367035
07/06/09 07:21 PM
07/06/09 07:21 PM
Harrisburg, Pa.
Harrisburg, Pa.
And lastely, a pic of the axle bracket...I ditched the isolated rear spring set-up so I welded a washer in the bigger locating hole to reduce it down to the smaller,old style locating pin...Your's should have the bigger holes for the isolated set-up and that's why I'm showing this pic...Your welcome... ...
Re: need pics of 73-4 roadrunner front and rear sway bars [Re: screamindriver] #367036
07/06/09 10:42 PM
07/06/09 10:42 PM
Nashport, OH
Nashport, OH
Awesome pics!Thanks screamindriver.It looks like I have all the parts but my k member doesnt have the braces for the end links to bolt to.I may have to get creative for brackets.
Re: need pics of 73-4 roadrunner front and rear sway bars [Re: chargers777] #367037
07/06/09 10:58 PM
07/06/09 10:58 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Great pics screamindriver, did you find the sway bars to make a lot of handling difference in these cars?
Re: need pics of 73-4 roadrunner front and rear sway bars [Re: DaytonaTurbo] #367038
07/07/09 08:43 AM
07/07/09 08:43 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I did, my car didn't get rear sway bar from factory and now it does have... and yes it makes difference
Re: need pics of 73-4 roadrunner front and rear sway bars [Re: NachoRT74] #367039
07/09/09 06:17 PM
07/09/09 06:17 PM
Harrisburg, Pa.
Harrisburg, Pa.
Yes just like any other mopar the bars make a huge difference...If you're after better handling out of the isolated K member then the aluminum or poly k frame bushings are a must also....There's a member on here that has the whole aluminum set-up including the trans crossmember and I'm thinking that would be my route on the next resto...The vehicle in the pics got the complete poly system.....And a bunch of mods including a k frame skid plate ...And don't forget...There are alot of vehicles out there with the isolated set-ups {cordoba, magnum,charger, etc...} and I'd think it would be easier to locate one in the boneyard and have them torch the k frame brackets off so you could add them to your car if it needed them...They're a pretty beefy piece and that would be the easiest route instead of fabricating them...
Re: need pics of 73-4 roadrunner front and rear sway bars [Re: screamindriver] #367040
07/09/09 09:53 PM
07/09/09 09:53 PM
Nashport, OH
Nashport, OH
Got the front swaybar on today.I fabricated some mountswasnt too hard.I modeled them after the originals.Iwelded and bolted them in.When I drove the car it made a huge difference.The front end didnt seem to wallow as much.The whole car felt tighter.Now I need to put on the rear!Thanks for the pics screamindriver.
