Car "twists" at launch
#366453
07/04/09 02:52 PM
07/04/09 02:52 PM
Posts: 549 Bristol, Va
fasteddie
Bristol, Va
72 Dart with frame connectors and roll bar. Runs 12.0s in the heat of summer with 1.66 60 foot times.
This new motor makes more torque and we also put a low gear set in the trans.
It lifts the left front tire about 6 inches.
I'm looking to keep the car level at launch. The twisting seems like wasted motion, and it's probably not good for the car to twist that much.
Car has all stock suspension with a pinion snubber,regular shocks out back and Summit 3 way adjustable shocks up front. The rear leaf springs have been moved in to the frame rails and the springs have been de-arched (don't know why, it was that way when I got it.)
I'm thinking Caltracs and maybe the mono leafs would help but wanted to seek opinions from those who may have had similar problems.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Car "twists" at launch
[Re: fasteddie]
#366454
07/04/09 03:00 PM
07/04/09 03:00 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
You could try adding some preload in the left front, and right rear. The fact that the springs have been dearched may be contributing to the problem. SS type springs have been working very well for many years on cars that run faster, so thinking this through a bit should unearth the problem. Maybe try a borrowed set of springs?
Post deleted by Defbob
[Re: gregsdart]
#366455
07/04/09 03:54 PM
07/04/09 03:54 PM
[Re: gregsdart]
#366457
07/04/09 07:20 PM
07/04/09 07:20 PM
Posts: 4,209 New York
polyspheric
New York
Definitely - the torque bias engineered into the SS spring will help.
How are the subs hooked into the car? Bolted? Welded? How big?
Boffin Emeritus
[Re: fasteddie]
#366460
07/04/09 10:47 PM
07/04/09 10:47 PM
Posts: 43,230 Bend,OR USA
Cab_Burge
Are your current leaf springs clamped on all leafs on the front and one or two on the back? If not try clamping the springs on the front half and using one clamp on the back half, move the rear clamps around to different positions to help balance (level)the twist on the front I have done that on a leaf spring car, works good, last a long time. be patient and do one change at a time and write the changes down. My 440 powered Dart with SS springs(002/003) moved into the frame rails like the right rear clamp up real close to the rear end and the left rear back about two spring ends from the rear end housing you can also stiffen up the left front shock and run a real loose or drilled shock on the right front to help level the front end up on the hit at the starting line
[Re: Cab_Burge]
#366461
07/04/09 11:41 PM
07/04/09 11:41 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
On the clamps with stock springs I would use more on the passenger side front segment. That will give you some Launch load on that end to help you leave straight.
I run a 1.43 60 ft 10.47 et with stock springs and leave straight as can be, so im sure you can do the same. It will take some test and tune with the clamps and some front shock settings as stated by Cab. mike
73 Sport 440, 509 cam w/Eddys 3.91 and 28.1"/27.3 tire. Et. 60 ft. 1.435, 1/8th. 6.61 @ 101.80 mph. 1/4. 10.472 / 127.78 mph. 2950# race/with me,and pump gas.
[Re: fasteddie]
#366462
07/05/09 08:46 AM
07/05/09 08:46 AM
Posts: 2,252 Sebring, Florida
Mopar Grandpa
Sebring, Florida
I would strongly suggest you contact Mike Roth @ MR2 Performance in Lebanon, Indiana. He is the expert when it comes to suspension problems and remidies. Most of the time it takes more than changing one area as every component has to work in harmony to get the car to launch properly. He does a lot of work on the SS/AH cars, B bodys, etc. and really knows his stuff.
[Re: Cab_Burge]
#366465
07/05/09 10:50 AM
07/05/09 10:50 AM
polyspheric
New York
"stiffen up the left front shock"
Yup. If the shock is still good (and $$$ to replace), try substituting polyurethane for the rubber donuts. This will make the valving work almost as soon as the hock moves, instead of delaying it while the rubber compresses.
Boffin Emeritus
[Re: fasteddie]
#366466
07/05/09 10:56 AM
07/05/09 10:56 AM
Posts: 1,532 off the grid
340B5
off the grid
The pinion snubber is most likeley right up against the floorboard. Try 1/2" gap if you want to use it. A recent post here say the best place for a snubber is in the trash can.
Yeah, it's got a smallblock.
[Re: max_maniac]
#366468
07/05/09 11:50 AM
07/05/09 11:50 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
there is a video out there of a Peterbilt twisting! Like cartoon like
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
