limited slip vs spool axle length
#366112
07/04/09 08:37 AM
07/04/09 08:37 AM
Posts: 74 virginia
tigger1
virginia
I have a chance to purchase a set of moser axles but they are just a little too long. If I switch to a spool will the axles go farther into a spool since there are no spider gears and pins? Even if I were to cut the axles they would be about 1/4 inch too long with my LS rear. thanks
Twin turbo 440 72 barracuda
Re: limited slip vs spool axle length
[Re: DoctorDiff]
#366114
07/05/09 12:27 AM
07/05/09 12:27 AM
Posts: 74 virginia
tigger1
virginia
Dr. Diff. Is a spool splined all the way through and if so what is the price for a spool for a ford 9 inch with 35 spline axles? I tried to ask through privite message but it says your quota has been exceeded. Thanks Steve
