E-body remote mirror question #365954
07/04/09 12:10 AM
07/04/09 12:10 AM
Anchorage, Alaska
Iceman01 Offline OP
Challenged
Iceman01  Offline OP
Challenged
Anchorage, Alaska
Could someone please measure their 1970 Challenger inside drivers door panel for the correct mounting location of the remote side-view mirror toggle lever?
I'm installing my restored door panels and discovered there is no hole in the driver side to mount the remote mirror toggle lever. I bought the car disassembled and with its original door panels, so apparently the car came new with a standard mirror and the previous owner bought this remote model to install. Now I have to cut a hole and want to be sure I do it in the right place.
There is a stamped, dotted circle on the backside in the area where the hole should be, but the same marking also exists on the passenger door panel (where no remote mirror was available), so I'm not certain it is the correct location.
Until total honesty is on the table, we're not even talking about reality...
Re: E-body remote mirror question [Re: Iceman01] #365955
07/04/09 12:27 AM
07/04/09 12:27 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The spot is marked (both sides for whatever reason) but they did not always hit it exactly......
Re: E-body remote mirror question [Re: Alaskan_TA] #365956
07/04/09 12:27 AM
07/04/09 12:27 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Size;
Re: E-body remote mirror question [Re: Alaskan_TA] #365957
07/04/09 03:33 AM
07/04/09 03:33 AM
Anchorage, Alaska
Iceman01 Offline OP
Challenged
Iceman01  Offline OP
Challenged
Anchorage, Alaska
Thanks Barry, that's the mark I was referring to on the back of mine. Weird that it would be on both sides though. Anyhow, I'll verify cable length/operation before cutting.
Re: E-body remote mirror question [Re: Iceman01] #365958
07/04/09 03:46 AM
07/04/09 03:46 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
You can double check it with your inner door panel.
Re: E-body remote mirror question [Re: Iceman01] #365959
07/07/09 01:30 AM
07/07/09 01:30 AM
Anchorage, Alaska
Iceman01 Offline OP
Challenged
Iceman01  Offline OP
Challenged
Anchorage, Alaska
Okay, so I go out to mock it all up before cutting and discover that the cables as currently routed are not long enough to reach the inner door panel. They are currently running from the mirror down through a hole in a stock-looking bracket bolted to the inside front vertical edge of the actual door. The bracket is pointing downward with the hole located approximately mid-door. With the cable routed through it, there is not enough slack to route it back up to the correct location on the inside door panel. It does look like the bracket could be rotated 180 degrees to point upwards instead. That might provide the needed slack. Can anyone confirm the correct cable routing and bracket placement?
Re: E-body remote mirror question [Re: Iceman01] #365960
07/07/09 01:41 AM
07/07/09 01:41 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
How long is your cable? (my inner door bracket is bagged & tagged - someplace)
Re: E-body remote mirror question [Re: Alaskan_TA] #365961
07/07/09 03:38 AM
07/07/09 03:38 AM
Anchorage, Alaska
Iceman01 Offline OP
Challenged
Iceman01  Offline OP
Challenged
Anchorage, Alaska
The door, glass and mirror are assembled so I can't get an exact measurement, but it looks to be around 30 inches.
Once I took it out of the downward-pointing bracket, I had plenty of slack. I'm pretty sure if I flip the bracket 180 degrees (point it up) everything will work fine. Hoping someone can confirm. I'm gonna dig out the shop manual and see if there is a diagram.
Re: E-body remote mirror question [Re: Iceman01] #365962
07/08/09 11:44 AM
07/08/09 11:44 AM
Anchorage, Alaska
Iceman01 Offline OP
Challenged
Iceman01  Offline OP
Challenged
Anchorage, Alaska
Flipped it around and it works fine. The bracket is bolted in through a hole in the front vertical edge of the door.
Re: E-body remote mirror question [Re: Iceman01] #365963
05/11/13 06:54 PM
05/11/13 06:54 PM
OHIO
faud88 Offline
faud88  Offline
OHIO
Digging up a old post, does any one have a picture of the inside of the door showing the bracket and how it bolts up? I can only seem to get it bolt up one way and thats pointing down putting the cable in too much strain.
Thanks,
Paul
Re: E-body remote mirror question [Re: faud88] #365964
05/11/13 07:04 PM
05/11/13 07:04 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
I just replaced a driver side mirror on a 70 Challenger,and the bracket should point up.The cable is now up and forward of the door glass
Re: E-body remote mirror question [Re: faud88] #365965
05/11/13 07:29 PM
05/11/13 07:29 PM
OHIO
faud88 Offline
faud88  Offline
OHIO
This is the only way I can get the bracket to line up...
Re: E-body remote mirror question [Re: faud88] #365966
05/11/13 07:31 PM
05/11/13 07:31 PM
OHIO
faud88 Offline
faud88  Offline
OHIO
My Bracket....
Re: E-body remote mirror question [Re: faud88] #365967
05/11/13 07:32 PM
05/11/13 07:32 PM
OHIO
faud88 Offline
faud88  Offline
OHIO
Side View....
Re: E-body remote mirror question [Re: faud88] #365968
05/11/13 07:33 PM
05/11/13 07:33 PM
OHIO
faud88 Offline
faud88  Offline
OHIO
The area in the door I am using to bolt the bracket...
Re: E-body remote mirror question [Re: faud88] #365969
05/11/13 07:36 PM
05/11/13 07:36 PM
OHIO
faud88 Offline
faud88  Offline
OHIO
This is with the bracket flipped up. I agree the cable would be much better if I could get it to stay this way. But the way the nut is welded to the bracket you cannot bolt it up this way...
HELP!
Re: E-body remote mirror question [Re: faud88] #365970
05/11/13 08:59 PM
05/11/13 08:59 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
This way is correct. The bolt comes in from the hole in the front outer skin, you can install it with a socket.
Re: E-body remote mirror question [Re: faud88] #365971
05/11/13 09:04 PM
05/11/13 09:04 PM
CT
1932chrysler Offline
CT
hope this helps i have 2 photos of routing on a original factory remote mirror 1971 challenger
donald
1932 Chrysler CI Sedan
1956 Pontiac Catalina Sedan
All Makes & Models Are Special
Re: E-body remote mirror question [Re: 1932chrysler] #365972
05/11/13 09:06 PM
05/11/13 09:06 PM
CT
CT
2
Re: E-body remote mirror question [Re: 1932chrysler] #365973
05/11/13 09:55 PM
05/11/13 09:55 PM
OHIO
faud88 Offline
faud88  Offline
OHIO
1932, 1970 must be unique I don't see a bracket in yours at all. Thanks for the pictures.
Paul
