does a trans cooler help 440? #365755
07/03/09 09:39 PM
07/03/09 09:39 PM
Kenosha, WI wi/il border
BobN Offline OP
BobN  Offline OP
will putting trans cooler on help
440 run cooler? Or just safe measure for trans?
I am concered about blocking air flow in front of radiator.
I haveent put in on since I cant figure out best spot on 68 coronet where to mount thre trans cooler.
Can anyone show me pics of where they have theres mounted.
thanks
Re: does a trans cooler help 440? [Re: BobN] #365756
07/03/09 10:30 PM
07/03/09 10:30 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
It will help run cooler.
I have heard of guys running one in remote locations. I did this on my own car with mixed results. Not much room for a fan, or a big cooler when remote located on a car.( I did the same thing on my winni, and it worked awesome!)
I'm considering going to a bigger cooler in front of the rad, on the car to see if it will help keep it cool.
Re: does a trans cooler help 440? [Re: dave571] #365757
07/03/09 10:37 PM
07/03/09 10:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If you want to mount it on the frame rail this design works pretty well..
Re: does a trans cooler help 440? [Re: BobN] #365758
07/03/09 11:01 PM
07/03/09 11:01 PM
It'll reduce the radiator cooling ability a miniscule amt but will greatly benefit the trans longevity.
