Page 2 of 3 1 2 3
Re: 440 Runs hot/overheats. Need help!!!!!!!!! [Re: JSSuperbee] #365454
07/04/09 03:06 AM
07/04/09 03:06 AM
Scottsdale, AZ
Cudalord Offline OP
Cudalord  Offline OP
Scottsdale, AZ
Yeah, it's holding pressure. I had the radiator checked by a professional and he said the radiator is in excellent condition. My big question is......I've changed nothing except a rebuild and .030 over, why would it need a shroud now if it didn't need one when it was manufactured?
Don't hijack my post dude, I'm on a mission. haha!!!
Re: 440 Runs hot/overheats. Need help!!!!!!!!! [Re: Cudalord] #365455
07/04/09 06:29 AM
07/04/09 06:29 AM
Australia
charger RTSE Offline
Australia
water pump pulley have you tried a differant sized one so the pump will turn quicker say a smaller one of an Air Con car.
Re: 440 Runs hot/overheats. Need help!!!!!!!!! [Re: Cudalord] #365456
07/04/09 07:51 AM
07/04/09 07:51 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Right now I have the electric fan on it. It runs noticeably cooler when the temp outside is below 90, so I stuck with it. I've tried the stock setup and just about every combination. NOT a shroud issue... I wish it was that simple....
You need a better fan and a shroud. My stock cooling system can idle all day long with the AC cranking. You need a 7 blade fan and shroud, I'm telling you.
How much initial timing do you have and what is the total?
Re: 440 Runs hot/overheats. Need help!!!!!!!!! [Re: JSSuperbee] #365457
07/04/09 08:40 AM
07/04/09 08:40 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I too have the overheating problem on my newly rebuilt 383. My Bee was manufactured without a shroud. Certainly these cars built without shrouds were engineered to operate in the proper heat range. According to a recent publication by Paul Hurd....cars manufactured with the 22" radiator only received shrouds when they were equipped with A/C or the MAX COOL option.
That would only be true if the car was an A body , everything else with A/C and/or MAX COOL had a 26" radiator
Re: 440 Runs hot/overheats. Need help!!!!!!!!! [Re: JohnRR] #365458
07/04/09 09:03 AM
07/04/09 09:03 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
"The car peaks at about 240, no matter if I'm on the freeway, at idle, driving down the road at 25, 35, 45, 55 miles per hour."
Did some of you read the first post
240 on the freeway / driving down the road
What the hell is a shroud/fan going to do on the freeway to fix the issue NOTHING NOTHING NOTHING Now if it was only at idle sitting in stopped traffic that would bee a different story
IT sounds like you have exhausted all options
Now its time to look internally/engine/heads like others have mentioned
Timing Chain and timing
Head Gaskets
Coolant flow thru the blocks and heads/RESTRICTION somewere or blocked
Re: 440 Runs hot/overheats. Need help!!!!!!!!! [Re: bee1971] #365459
07/04/09 09:26 AM
07/04/09 09:26 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
ditti on the timing...bring it to TDC not by the timing mark either.... the car should run like ppoo pooo w/ that low of timing, my guess is something's up w/ that. if you had a head leak it'd either blow it out the back or you'd have a bunch of pressure into the rad.. goooood luck.
Coming soon!!!!
Re: 440 Runs hot/overheats. Need help!!!!!!!!! [Re: Mr.Yuck] #365460
07/04/09 09:55 PM
07/04/09 09:55 PM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
wrong head gasket??
Re: 440 Runs hot/overheats. Need help!!!!!!!!! [Re: BigTerry] #365461
07/04/09 11:26 PM
07/04/09 11:26 PM
Nashport, OH
chargers777 Offline
chargers777  Offline
Nashport, OH
Plugging the heater hose ports might cause a problem with circulation.Can you hook your hoses or is your heater core bad?If it is loop a hose in a loop and connect them together and see if it helps.Easy to try but if that is not it I would look at the head gasket.Also what size diameter water pump pulley are you running-smaller is better.
Re: 440 Runs hot/overheats. Need help!!!!!!!!! [Re: chargers777] #365462
07/05/09 12:21 AM
07/05/09 12:21 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
The lost secret is the impeller blades on AC cars were smaller and moved less water per revolution than the standard pump, and this was necessary because the pulley diameters changed for AC cars and they turned the pump much faster than non AC cars.
The correct answer is the non ac pump impellers
8 fins as I remember and a towing fan 7 blade fixed hub) And the correct diameter pulleys for the crank and water pump.
Everything must match... a 4 row copper/brass radiator will help as well.
Re: 440 Runs hot/overheats. Need help!!!!!!!!! [Re: sthemi] #365463
07/05/09 02:43 AM
07/05/09 02:43 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
The only thing that sticks out to me is that you seem to have better luck when the timing is "off"- pointing to the TDC mark being off.
I would also look in the radiator again. I had a car that was cooking itself to death. I had the radiator boiled out and it did great- got lots of sand out.
All was well until I raced a guy for several miles one night on the interstate. Car boiled over like you would expect. The the next day it was overheating again like before. I looked over all sorts of stuff and happened to look down the neck as I went to refill it again. MORE sand had been pushed out.
I want my fair share
Re: 440 Runs hot/overheats. Need help!!!!!!!!! [Re: SomeCarGuy] #365464
07/05/09 08:48 PM
07/05/09 08:48 PM
Rochester HIlls, MI
Blue66Charger Offline
Rochester HIlls, MI
My money is on timing. EAsy and cheap to check - follow previous timing suggestions to check!
Re: 440 Runs hot/overheats. Need help!!!!!!!!! [Re: Blue66Charger] #365465
07/05/09 10:03 PM
07/05/09 10:03 PM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
did you bore the block .040 or over? a friend of mine had a overheating problem on a 383 he built for a street car it was bored .060 it ran hot from day one he talk to a fellow who built race engine for some nascar teams a few year back he said the cylinder wall where too thin and was heating the coolant up! said that would happen on any motor bore .045 or more those motor would only be good for Drag racing unless he want to spend the extra money for a better cooling system and electric fan..
Re: 440 Runs hot/overheats. Need help!!!!!!!!! [Re: BigTerry] #365466
07/06/09 01:06 PM
07/06/09 01:06 PM
P
Paul_Fancsali Offline
P
Are you running headers or manifolds. I found out the hard way that some engines need headers period with a cam above stock replacement. I chased a running warm problem for 3 month's until I put the headers back on and problem solved/225 to 185 on a 85 degree day with a 180stat
Re: 440 Runs hot/overheats. Need help!!!!!!!!! [Re: Paul_Fancsali] #365467
07/08/09 01:42 AM
07/08/09 01:42 AM
Scottsdale, AZ
Cudalord Offline OP
Cudalord  Offline OP
Scottsdale, AZ
Well, after doing some research and listening to your suggestions, I decided to check out the timing. So, I did the following:
I put the #1 to TDC by rotating the engine until the comp stroke and aligned on the balancer to exact TDC. I confirmed it was at TDC by removing the valve covers and noticed the intake/exhaust rockers were loose.
Pulled out the distributor and saw something interesting. The gear drive was not exactly in line with the camshaft. It was off one tooth. I put it in line with the camshaft, made absolute the rotor was pointing to #1 and put back together.
I then put a mark on the balancer per the previous recommendation, and used that to set timing.
After doing all this, I did notice the car ran considerably smoother and had a lot of power. No pinging or anything. I was hoping it would run cooler, which it did stay under 200 while having it running in the garage for about 15 minutes. Tomorrow I'm taking it out for my morning commute to see how it holds up.
I didn't put the thermostat back in yet, but I don't think this will have anything to do while it's running at/above operating temp, right? I'm putting it back in tomorrow anyway since I didn't notice any difference with it out or in....
Re: 440 Runs hot/overheats. Need help!!!!!!!!! [Re: Cudalord] #365468
07/08/09 03:17 AM
07/08/09 03:17 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Re: 440 Runs hot/overheats. Need help!!!!!!!!! [Re: Quicksilver440] #365469
07/08/09 07:10 AM
07/08/09 07:10 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
" didn't put the thermostat back in yet, but I don't think this will have anything to do while it's running at/above operating temp, right? I'm putting it back in tomorrow anyway since I didn't notice any difference with it out or in...."
good job on finding the problem, yes the thermo in will help cooling as it allows the water to saty in the Rad long enough to get cool..well coooler anyway. 200 isn't bad.
Coming soon!!!!
Re: 440 Runs hot/overheats. Need help!!!!!!!!! [Re: Cudalord] #365470
07/08/09 11:21 AM
07/08/09 11:21 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
UNLESS the balancer mark was off, you basicly changed nothing
Re: 440 Runs hot/overheats. Need help!!!!!!!!! [Re: 05dakota] #365471
07/08/09 11:30 AM
07/08/09 11:30 AM
Cincinnati, Ohio
Cincinnati, Ohio
That's what I was thinking,
Re: 440 Runs hot/overheats. Need help!!!!!!!!! [Re: Challenger 1] #365472
07/08/09 11:43 AM
07/08/09 11:43 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
He probably reset the timing which corrected the trouble.
Re: 440 Runs hot/overheats. Need help!!!!!!!!! [Re: Cudalord] #365473
08/14/09 02:48 PM
08/14/09 02:48 PM
Detroit, MI
kz5rt2 Offline
kz5rt2  Offline
Detroit, MI
Has this cooling issue been resolved? Also, does if a block is bored out 0.060" does this mean it's impossible to cool with a stock setup (including all the goodies).
Page 2 of 3 1 2 3
