Re: Belvedere Brake Problem ???
[Re: als499]
#365361
07/03/09 05:18 PM
07/03/09 05:18 PM
RapidRobert
That is a strange one. I'd start by turning the wheel left the same amt & inspecting the flexible brake hoses on both sides. It does that EVERY time (turning left @ 5mph)? Hopefully so as that will make it easier to spot.
[Re: als499]
#365363
07/03/09 05:38 PM
07/03/09 05:38 PM
RapidRobert
I'm sure you've inspected everything from front to rear and with the car stopped can you get it to act up? and power or manual? I keep thinking M/C/booster related esp since both halves(front/rear) are going out.
[Re: RapidRobert]
#365364
07/03/09 06:46 PM
07/03/09 06:46 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
If it was a PB booster the pedal would be rock hard.Had a Blazer that did that.The bolt on the hose was touching when at full turn.Pedal would go down.Rocky
Chrysler Firepower
