correct PCV valve for '70 BB #364890
07/03/09 12:29 AM
07/03/09 12:29 AM
SE Pa.
LimeliteAero Offline OP
SE Pa.
What should be the correct PCV valve for a 12/69 built 440+6. currently I have the metal valve but Ive been told I should have the metal/plastic piece.
The car had 39,000 +/- miles on it when I got it. could that still be the original or was it most likely replaced?
the current valve is painted in what seems to be a darker orange than is on the valve cover.
Re: correct PCV valve for '70 BB [Re: LimeliteAero] #364891
07/03/09 12:52 AM
07/03/09 12:52 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
All '70 big blocks should have the plastic "barrel" PCV with 3 vanes.
Re: correct PCV valve for '70 BB [Re: 6bblgt] #364892
07/03/09 02:27 AM
07/03/09 02:27 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
stolen off ebay .......
Re: correct PCV valve for '70 BB [Re: 6bblgt] #364893
07/03/09 07:45 AM
07/03/09 07:45 AM
MD
floyd Offline
floyd  Offline
MD
I didn't realize the small bocks got a different one.
Re: correct PCV valve for '70 BB [Re: floyd] #364894
07/03/09 09:04 AM
07/03/09 09:04 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
bruce,
Although, I obviously han't seen them all - the unrestored cars I've seen the 1970 big block cars received the ribbed barrel and small blocks received the smooth barrel, then in 71 most (but have serious doubts all did ) received the smooth barrel
Re: correct PCV valve for '70 BB [Re: gtx6970] #364895
07/03/09 09:31 AM
07/03/09 09:31 AM
MD
floyd Offline
floyd  Offline
MD
Thanks Bill - You have the reproduction ribbed ones right?
Re: correct PCV valve for '70 BB [Re: floyd] #364896
07/03/09 09:42 AM
07/03/09 09:42 AM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Both types are correct for 1970 motors except Hemi. This is well documented. I have seen (and have) both styles (still with original engine paint on them) on my engines. Even the engineering documents (which aren't always the law) show both vendors. One is made by Chicago Screw - the other I dont remember at the moment. All 70-71 Hemi's I have seen are the 3 rib. Original 3-rib have "No-Vo" stamped onto the shoulder.
Re: correct PCV valve for '70 BB [Re: FJ5_Fish] #364897
07/03/09 11:07 AM
07/03/09 11:07 AM
NY
twodoorpost Offline
twodoorpost  Offline
NY
Here's an OE on a April 1970 built cuda 440ci engine.
Re: correct PCV valve for '70 BB [Re: LimeliteAero] #364898
07/03/09 11:42 AM
07/03/09 11:42 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Post a picture, the darker color is most likely due to heat. In fact the grommet usually ends up dark over time also...
Re: correct PCV valve for '70 BB [Re: RJS] #364899
07/03/09 12:10 PM
07/03/09 12:10 PM
SE Pa.
SE Pa.
I could post a pic of the valve but the rest of the engine is out of house getting a little treatment.
Re: correct PCV valve for '70 BB [Re: twodoorpost] #364900
07/04/09 11:29 AM
07/04/09 11:29 AM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
So they should be painted????70 RR???
Re: correct PCV valve for '70 BB [Re: 70RR383] #364901
07/04/09 12:34 PM
07/04/09 12:34 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Always, unless the car had factory chrome valve covers or black wrinkle valve covers.
