Re: New Paint job on a budget thread.
#36434
05/23/07 03:33 PM
05/23/07 03:33 PM
well i still havent final wetsanded and polished my hood yet and to tell you the truth it almost looks good as is... almost. i'll worry about the finish when i get the rest of the car covered. http://img102.imageshack.us/my.php?image=p1010283wc7.jpgofftopic: by any chance would anyone know how to get lock lugs off with out a key.. i need to take my tires off to do some bodywork (first time iv tried taking them off since getting this car a year ago) and tada it has lock lugs so im kind of stuck
#36435
05/23/07 04:21 PM
05/23/07 04:21 PM
I too experimented with spraying, and I think your downfall is going to be the small compressor.
I sprayed some and it turned out good, but my small compressor 2.5 hp,30 gallons couldnt keep up and so after a few passes I would start to get weak spray and "spittle" from the gun since the pressure was dropping.
I would definatly practice on a hood or something and see if you really like how it turns out. DONT use acetone as recommended. I tried and it flashed hazy since acetone evaporates in like 2 seconds, use mineral spirits.
Curious to see what size compressor MyBUICK used.
#36436
05/23/07 05:30 PM
05/23/07 05:30 PM
Find a socket that just fits on the outside of the luglock and beat it on. then remove. otherwise most tire stores and tool trucks sell sockets that have teeth inside so you can beat them on and remove the locks.
#36437
05/23/07 07:51 PM
05/23/07 07:51 PM
Hey guys I just joined up because of this thread. I rolled the tailgate of my el camino tonight. I used 5% thinned brightside and 2 high density foam rollers, one to apply, one to work out bubbles. I followed the steps of cleaning the surface and wiping with a tack cloth. After applying it I have major orange peel. I have no idea why it isnt laying flat. Any opnions? I thinned it with interlux brushing liquid. I prepped the paint with 220 grit.
#36439
05/23/07 09:00 PM
05/23/07 09:00 PM
u must be putting it on too heavy, i rolled brightside straight and the peel wasnt too bad. u werent doing it in the sun were u?
#36440
05/23/07 09:09 PM
05/23/07 09:09 PM
No I didnt do it in the sun. It didnt look too thick when I rolled it? Im gonna sand it tomorrow and try again.
#36441
05/23/07 11:23 PM
05/23/07 11:23 PM
i have a 6hp 30 gallon craftsman compressor and it kepped up verry well with no spitting and set to 40 psi with a water seperator and i use the 50.00 hvlp gun from eastwood 2 of them 1 for color and 1 for clear.
the 2.5 i think would stay on all the time because i wont fill the tank fast enough while painting it takes me 5 min for 1 coat to lay down and the compressor kicks on once
i had one fan blowing out of a window and the grage door open a foot then when i was done spraying i would open the door and let all the overspray linger out.
#36442
05/23/07 11:27 PM
05/23/07 11:27 PM
take them off with a hammer and a chisel thats how the crooks steal the rims. if you have a air chisel it will work faster.
[Re: Marq]
#36443
05/24/07 07:07 AM
05/24/07 07:07 AM
Hey Marq, Aussie Driver or Exit, or others using Brightside....I am using Aussie Drivers ratio of Brightside, penetrol and mineral spirits. the first two coats went down fantastic, almost like glass. I did my first wet sand with 600 and then third coat...that is where things changed a little. I stated to get very small bubbles that would magicaly appear after I thought things were perfect...they came in small patches....so I did my second wetsand with 600 thinking that would clear things up.
on my fourth coat I have some major orange peel and the same small patches of micro-bubbles...this all occured ONLY where I had wetsanded the previous "mistakes".
so I have two questions: do you think those areas were contaminated somehow?
will the final 1000/1500 wetsand and the polish remove this? or do I need to sand again with 600 and lay another coat down and then do the finalsand/polish/wax?
#36445
05/24/07 10:29 AM
05/24/07 10:29 AM
Posts: 5,660 Flint, MI
Gusteve
I Love the Unicorn Song!!
Flint, MI
Rolled her out into the sun, the satin black looks better out of the garage
Gene -
Thanks for posting that pic. I was wondering just the other day what your car looked like out in the sun.
I'm still trying to decide between satin and gloss. Hopefully I'll have the rest of my paint prep done this weekend and maybe even start rolling on Monday.
I know that Satin will be A LOT easier than gloss. But I keep thinking that since I have the car all apart, I might as well try and do gloss. I probably won't have it dis-assembled to this level again for years, and hopefully never. (1 vote for Gloss)
At the same time, Gloss Black is probably the hardest color to get right, not to mention that my potentially less than perfect body prep is going to show up a lot more if I try gloss. (1 vote for Satin).
Could I ask you to post a couple more pics? The last one was slightly blurry, or maybe just low-res (no offense intended).
If I could see a few more, it would help greatly with my final decision.
Thanks!
#36446
05/24/07 10:36 AM
05/24/07 10:36 AM
Gusteve
Flint, MI
Yes, the white can with the patio furnature on it.
After 3 weeks, it is really hard now, I banged it with a ratchet yesterday and didnt scratch at all.
Isn't the can with the Patio Furniture on it the Rustoleum "Painter's Touch" line? I thought that was Lacquer, where the stuff from the roll-on can is enamel.
[Re: Gusteve]
#36447
05/24/07 01:55 PM
05/24/07 01:55 PM
Steve- If the level of dissasembly is what is holding you up consider this:
Some of the cars we have built for the "rat rod" crowd (and I did on my other drag car) is to edge all of the panels, door openings etc in the color you may end up wanting (gloss). then do the body satin (or with a flattener if spraying normal single or two stage paints)and live with that for as long as you want. it will also help show imperfections, and give a better base under black if you go gloss, as chips will not show as badly.
Then if you go gloss down the road the jambs and such are already edged and you can just back mask it.
[Re: Gusteve]
#36448
05/24/07 05:57 PM
05/24/07 05:57 PM
No, just went and looked at the cans to make sure. it says "protective enamel" in big letters. Not painters touch line.
[Re: Gusteve]
#36449
05/24/07 06:02 PM
05/24/07 06:02 PM
That's exactly what I did too. I tried the gloss black, but (duh) it revealed all my amatuer body work. plus I got a bunch of bugs caught in it. I did like 6 coats gloss on the hood, and really worked on it but just couldn't get it to a level that I though would pass as a "real" paint job. Black is SO hard, I have MUCH respect for Aussi and others that have made it work. The gloss is a fine base for Satin, so you could just try the gloss, if it turns out good then keep it if not, then just scuff and throw down a few coats of satin and be done with it until you win the lottery and can get a 5k paint job. Here are some more pics: http://s150.photobucket.com/albums/s97/gfeighny/Sorry, the resolution isn't great. If you email me (gfeighny AT gmail dot com) I'll send you the full resolution.
[Re: Marq]
#36450
05/24/07 07:44 PM
05/24/07 07:44 PM
Marq, thanks for the reply. I have been very patient with the whole project with the exception of the last coat. I have been waiting a couple of days between laying down a coat and then wetsanding....this last coat I wetsanded, washed clean, let dry about an hour and then wiped down with mineral spirits, and the layed the fourth coat on. After thinking about it here is what has been different: temperature was a little higher with higher humidity. I was using my mixture that had been stored in a sealed container for a few days and then added some more brightside to thicken it up a little for the final coat (per your reccommendations about 100 pages ago!) what do ya think? what about the final wetsand and polish? should I do that now or sand down and lay some more coats on?
#36451
05/24/07 10:35 PM
05/24/07 10:35 PM
Posts: 575 Canada
Marq
mopar addict
mopar addict
Canada
what do ya think?
Humidity would definitely be a factor. The higher the humidity the longer you have to wait for it to cure.
BUT humidity would not normally impact just one particular patch. It would tend to affect the whole surface.
If this situation happened to me... I would rework that entire panel rather than go jumping to the polish and waxing stage. IF you can nail it perfectly, you will save yourself work during the final stages.
That is one of the beauties of the 'roller' method. In that if you botch a panel.. you can simply redo that panel and the reworked panel will simply blend in with the other panels and not stand out visually as a reworked panel.
Dunno... that is how I would go about it. Your long term satisfaction will probably be ensured, rather than suffering with that 'long term' 'what if I had taken that extra bit of time and effort' to perfect it...
[Re: Gusteve]
#36453
05/25/07 12:33 AM
05/25/07 12:33 AM
Posts: 44 USA
_Scott_
USA
Something to consider regarding whether to go gloss or satin. To the trained eye, there is no difference in how one hides imperfections over the other. To the untrained eye, there is not much difference either, other than the gloss or lack thereof.
I recommend that if the car looks better with a gloss finish, do a gloss finish. If your inadequate body work skills show through, then hone those skills. Don't settle for a finish you don't really want just to try to hide imperfections, because as I said, to the trained eye they will show through anyway and to the untrained eye they would go unnoticed regardless of the gloss/satin finish.
And just to toss my $0.02USD in, a satin or even flat finish works on an old* rat rod, but doesn't work on a Civic for example. Not to say that it can't, just that I haven't seen anyone really pull it off yet.
* where old means ~40 or more years old.
