Valve cover to booster interference #364398
07/02/09 11:55 AM
07/02/09 11:55 AM
washington
Bruce Offline OP
Bruce  Offline OP
washington
After my son installed his 508 inch RB with INDY SR heads in his 1970 Challenger he noticed that the drivers side valve cover is touching the power brake booster.
Since this is probably a common problem, I was wondering any one had a solution to it.
Manual brakes is an option of course, if another brake booster is out. I have heard there is a better master cylinder to use than the stock boat anchor but don't remember where I saw the reference to it.
Thanks in advance.
Bruce
Re: Valve cover to booster interference [Re: Bruce] #364399
07/02/09 01:38 PM
07/02/09 01:38 PM
There are several different diameters of the power brake boosters that Mopar has used, the Hemi cars had smaller ones than the rest of the wedge or SB cars had
Re: Valve cover to booster interference [Re: Bruce] #364400
07/02/09 01:41 PM
07/02/09 01:41 PM
AndyF Offline
AndyF  Offline
Manual disc brakes work fine, especially if you install the larger 11.75 rotors. You can get an offset bracket for the master cylinder. Mancini Racing carries them as do a bunch of other places.
Re: Valve cover to booster interference [Re: AndyF] #364401
07/02/09 02:15 PM
07/02/09 02:15 PM
washington
Bruce Offline OP
Bruce  Offline OP
washington
thanks for the information guys.
Andy,
Which one of the adapters would we use for the 1970 challenger?
Thanks,
Bruce
Re: Valve cover to booster interference [Re: Bruce] #364402
07/02/09 09:58 PM
07/02/09 09:58 PM
AndyF Offline
AndyF  Offline
Any of those can be made to fit an E body car. Check to see which one your car prefers. Some cars have mounting studs in the firewall, other cars have holes in the firewall and the MC has the pressed in studs. It varies by year and model.
Re: Valve cover to booster interference [Re: Bruce] #364403
07/02/09 11:42 PM
07/02/09 11:42 PM
Chicago, IL
blownEFI Offline
blownEFI  Offline
Chicago, IL
I got this one from Master Power Brakes, it has an 8-inch diameter booster, clears fine with Indy heads
"These go to eleven", Nigel Tufnel
Re: Valve cover to booster interference [Re: blownEFI] #364404
07/03/09 01:15 AM
07/03/09 01:15 AM
washington
Bruce Offline OP
Bruce  Offline OP
washington
Once again thanks. Good information.
I like that power booster.
I will pass the information along to my son.
Bruce
Re: Valve cover to booster interference [Re: Bruce] #364405
07/03/09 04:17 AM
07/03/09 04:17 AM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I have manual front discs/rear drums on my charger. It stops great.
