Re: ??correct way to check stall ?? [Re: maximum entropy] #364104
07/02/09 05:32 PM
07/02/09 05:32 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
For gods sake do the testing where you have alot of room and no cars anywhere close. A buddy of mine was doing the Tranz Brake test in his drive way and ended up in the neihbors yard after he ran thur there bushes.
a racer from our track was testing his IN HIS GARAGE! oh, and he's the "chief" tech inspector at our track. and, yes, he went through the back of his garage.
....was there a button malfunfuction or something.. .if not,they must have let go of the button before the rpm's came down..i've done this test before and it only takes a few seconds for the rpm's to rise to your number then it's done...nothing to it ....unless you let go BEFORE the rpm's have came down...then you drive thru garages and the such. i've experimented with both techniques and they are usually within a few hundred rpm's of each other...i prefer the high gear test however...imo it's probably not quite as hard on parts as taken out the low end chip but both work when performed correctly....
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: ??correct way to check stall ?? [Re: Quicktree] #364105
07/02/09 05:57 PM
07/02/09 05:57 PM
St. Louis Mo.
10 o to go Offline OP
"Happy Don"
"Happy Don"
St. Louis Mo.
drop your shift point and see what happens. I doubt your blowing through the converter. did you give accurate info when ordering it?
quick tree yes i have but i'll check with them on those specs again i'm getting older so i don't remember all soon to be
51 this month and 32years racing .i was going to try short shifting.
stall or flash i have the brake set at 4000 might try 4400.
so what are we all trying to get a good launch and into the power band and shift overlap just starting at the power band again
thanks don
Re: ??correct way to check stall ?? [Re: 10 o to go] #364106
07/02/09 07:22 PM
07/02/09 07:22 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
I was there tues. Almost came over and said hi, but you were real busy. Watched a couple run(including you) before I left. Sorry I didn't notice anything that might help you but that thing sounds WICKED, I'm sure 9's are there,just have to find the majic combo. Its a whole new animal. Good Luck
Yeah, it's got a smallblock.
