If you run a transbrake....
Take out the two step chip, hold the trans brake button and hit the pedal to the floor quickly.
Look at the tach for the stall.
i run a brake so i'll try it that way. also i'll try hemifreds way . it doesn't seem like its dropping down enough to pull back through the next gear change . It seems to me i could go to a tighter convertor because of tordue in the motor and gain et and mph . i'll call turbo action paul forte ive run thier stufff since early 80s . ![](/ubbthreads/images/graemlins/beer.gif) thanks don
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
