driveshaft length?? #361854
06/29/09 06:56 PM
06/29/09 06:56 PM
eastern long island,NY
JeepJimmy Offline OP
I thought there was a chart in the tech section? 68 Dart 273, 2 door, 904, 8/3/4. I think the one i got for the car is too long. any ideas? on lengths?
70 duster 360magnum, 1975 jeep j-10.
Re: driveshaft length?? [Re: JeepJimmy] #361855
06/29/09 07:01 PM
06/29/09 07:01 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: driveshaft length?? [Re: DAYCLONA] #361856
06/29/09 07:02 PM
06/29/09 07:02 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
2
Re: driveshaft length?? [Re: DAYCLONA] #361857
06/29/09 07:07 PM
06/29/09 07:07 PM
Awesome!!! looks like 48.6 and i would assume thats center of U joint to center of U joint?
Re: driveshaft length?? [Re: JeepJimmy] #361858
06/29/09 09:05 PM
06/29/09 09:05 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I don't see a single 111" wheelbase A body on either of those tables.
Should be closer to 51.50-52"
https://board.moparts.org/ubbthreads/upload2/4563759-PartNoDriveshafts.pdf
Re: driveshaft length?? [Re: RobX4406] #361859
06/29/09 09:32 PM
06/29/09 09:32 PM
Since you have one in hand I would put it all the way in the trans(w springs loaded) & measure the C to C(subtract 3/4") which'll be the ideal length you need if you do end up having it cut rather than getting a different one plus you will have the correct dimention in hand in case the chart info is wrong(like the housing chart dimentions is said to be(wrong)on some of em.
