driveshaft length??
#361854
06/29/09 06:56 PM
06/29/09 06:56 PM
Posts: 1,271 eastern long island,NY
JeepJimmy
I thought there was a chart in the tech section? 68 Dart 273, 2 door, 904, 8/3/4. I think the one i got for the car is too long. any ideas? on lengths?
70 duster 360magnum, 1975 jeep j-10.
Re: driveshaft length??
[Re: JeepJimmy]
#361855
06/29/09 07:01 PM
06/29/09 07:01 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#361856
06/29/09 07:02 PM
06/29/09 07:02 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: RobX4406]
#361859
06/29/09 09:32 PM
06/29/09 09:32 PM
RapidRobert
Since you have one in hand I would put it all the way in the trans(w springs loaded) & measure the C to C(subtract 3/4") which'll be the ideal length you need if you do end up having it cut rather than getting a different one plus you will have the correct dimention in hand in case the chart info is wrong(like the housing chart dimentions is said to be(wrong)on some of em.
