Page 7 of 8 1 2 3 4 5 6 7 8
Re: 64 Plymouth Fury project [Re: mopar rookie] #361232
01/19/11 03:10 PM
01/19/11 03:10 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Hurry up...You can help me with my '64 Savoy and I'm just down the road from you.. Marysville. Why are you looking outside of central Ohio for an engine builder? There are number of good local machine shops.
fred
Re: 64 Plymouth Fury project [Re: 52savoy] #361233
01/19/11 07:20 PM
01/19/11 07:20 PM
central ohio
mopar rookie Offline OP
central ohio
Hey Fred i would be glad to help you on your 64. I know there are some good local machine shops but I just want a mopar guy to do my motor. I have talked with Jeff at Precision and Nick at Compuflow. I just need to pull the trigger so I can maybe make the Nats this year.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361234
01/19/11 08:17 PM
01/19/11 08:17 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Tell me about your motor...426 or 440 max wedge? specs...
Are you going to assemble it yourself?
Col-Weld in Columbus does very good work and so does FOWLER's but they(Fowlers) charge out the waaazoo. Performance Research has mopar experience also.
Wasserbeck is just north of Deleware but he takes his time.
http://www.wasserbeck.com/
http://www.fowlerengines.com/
http://www.priracingengines.com/
http://www.enginerebuilderssupply.com/aboutus.html
Re: 64 Plymouth Fury project [Re: 52savoy] #361235
06/03/11 10:21 PM
06/03/11 10:21 PM
central ohio
central ohio
Well I doubt that I will make the Nats this year but I did push the car outside today. It had been sitting in the same spot for a year. Needed to do some spring cleaning. I still dont know about the motor yet but leaning towards a 500 inch stroker. I will have someone else build it cause I just dont have the knowledge.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361236
06/03/11 10:25 PM
06/03/11 10:25 PM
central ohio
central ohio
Did fab up some mounts for my tranny cooler. Its nice to have a brother inlaw that owns a machine shop. Thanks Tracy
Re: 64 Plymouth Fury project [Re: mopar rookie] #361237
06/03/11 10:29 PM
06/03/11 10:29 PM
central ohio
central ohio
Welded the little spacers on and had them powder coated.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361238
06/03/11 10:38 PM
06/03/11 10:38 PM
central ohio
central ohio
The tranny cooler is from Setrab. They are located here in my hometown and are good friends. Most all cars in Nascar run thier coolers. Here it is mounted on car.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361239
06/03/11 10:46 PM
06/03/11 10:46 PM
central ohio
central ohio
Now I am fabbing up an aluminum glove box. I am going to mount the 6al on the bottom side of it.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361240
06/03/11 10:50 PM
06/03/11 10:50 PM
central ohio
central ohio
Just about ready to take it out and weld it together.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361241
06/06/11 07:13 PM
06/06/11 07:13 PM
Canada
Lugnutz Offline
Lugnutz  Offline
Canada
Re: 64 Plymouth Fury project [Re: Lugnutz] #361242
10/16/11 02:53 PM
10/16/11 02:53 PM
N.Y.
sixpacksteve Offline
N.Y.
Hell Hath No Fury Like Mine
Re: 64 Plymouth Fury project [Re: sixpacksteve] #361243
10/21/11 12:29 PM
10/21/11 12:29 PM
Missouri, Cole county
gbolten480 Offline
gbolten480  Offline
Re: 64 Plymouth Fury project [Re: gbolten480] #361244
10/22/11 06:11 PM
10/22/11 06:11 PM
Phila Pa
scatpacktom Online content
scatpacktom  Online Content
Phila Pa
Re: 64 Plymouth Fury project [Re: scatpacktom] #361245
10/23/11 09:58 PM
10/23/11 09:58 PM
So Dak
GOLDENCOMMANDO Online content
GOLDENCOMMANDO  Online Content
So Dak
Re: 64 Plymouth Fury project [Re: GOLDENCOMMANDO] #361246
10/30/11 11:01 PM
10/30/11 11:01 PM
Canada
Lugnutz Offline
Lugnutz  Offline
Canada
Re: 64 Plymouth Fury project [Re: Lugnutz] #361247
10/30/11 11:57 PM
10/30/11 11:57 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
What a nice 64 you are building. Ron
Re: 64 Plymouth Fury project [Re: 383man] #361248
12/23/11 03:29 PM
12/23/11 03:29 PM
central ohio
central ohio
Ok. got a few updates for you. Got my glove box back today from getting it powder coated.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361249
12/23/11 03:31 PM
12/23/11 03:31 PM
central ohio
central ohio
MSD installed on the bottom side
Re: 64 Plymouth Fury project [Re: mopar rookie] #361250
12/23/11 03:40 PM
12/23/11 03:40 PM
central ohio
central ohio
Installed in the car. Now I have a functional glove box and the MSD is hidden.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361251
12/23/11 03:44 PM
12/23/11 03:44 PM
central ohio
central ohio
Underneath view. got to get the wires ran out to the engine compartment and I can button up the insde.
