Re: Big block a518 overdrive conversion (lots of pics)
[Re: Rug_Trucker]
#36035
07/16/07 08:31 PM
07/16/07 08:31 PM
Posts: 1,490 smyrna,tn
draginmopars
smyrna,tn
Larry,, THANKS for the GREAT post.. My starters won't fit either The pilot hole should be 1 inch or larger.. it is .003 out of round,, I tried both early and late starters.. and YES, needs the bevel for the late starter.. thanks again for the heads up, on starter fit issues.. At least, i haven't installed the trans yet..
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
[Re: draginmopars]
#36036
11/24/07 10:28 AM
11/24/07 10:28 AM
draginmopars
smyrna,tn
Larry, did you ever get the starter to fit? I'm getting ready dis-assemble and cut the bell off. I'm going to en-large the starter pilot hole.
Howard
[Re: adventurer]
#36038
12/13/07 05:40 PM
12/13/07 05:40 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Great thread, should be put in archives, as this would apply to all mopar trans installing an ultrabell ..
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
