Re: How to hook up this throttle cable to my 950HP carb....
[Re: AndyF]
#359696
06/28/09 05:40 PM
06/28/09 05:40 PM
Posts: 2,410 Wichita,KS
Blakcharger440
Wichita,KS
What happened to the dual spring that came in the throttle return kit? Here is how the setup should look. I'd recommend using a stock cable with the crimped on ferrule. That way you have something solid to clamp to.
Where would I get a stock cable that is long enough? In your pic it shows a low rise dual plane intake. I have the Eddy RPM intake and it is quite taller.
Oh and i do have two springs I just forgot to put the second one on...the light springs that came in the kit are in my tool box as they seemed quite weak.
[Re: Blakcharger440]
#359701
07/02/09 10:02 AM
07/02/09 10:02 AM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
Oh sorry - 70 Duster but I believe any cable for the version of your car originally equipped with a slant six would provide the length needed.
Ride eternal, shiny and chrome
