A-833 BROKEN!! (Long post) #359623
06/27/09 01:57 PM
06/27/09 01:57 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Hey all! Yet another question for eveyone here! So I recently bought a 1970 4 speed for the Duster, got it home and realized that one of the ears was broken off!!
My question is: What should I do about this? Should I get it welded, get a new iron case, or get the O.D. aluminum case that the seller offered me?
My thoughts first off were that I would take the aluminum case. I know it is weaker than iron, and I would have to get a different front bearing and retainer size. Is that all I would have to do?? No machining or anything to make it all fit??
Next I was thinking get the iron case welded so I wouldn't have to go through the trouble of swapping cases (though I want to rebuild it anyway lol), but I don't know if it will hold up cuz I know how difficult it is to make a weld on castings strong. My gut tells me that I shouldn't go this route.
Finally I was thinking about getting a new iron case from Brewer's and get the rebuild kit at the same time. I kinda like the idea of the stronger case.
Anyways, with all this in mind, let me know what you all think! Thank you!!
I will post pictures if needed sometime tonight when I get out of work!
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: A-833 BROKEN!! (Long post) [Re: knyech1] #359624
06/27/09 02:01 PM
06/27/09 02:01 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
how badly is it broken? if its missing completely and the crack is propagating i would get another cast iron case. they are just about everywhere, i would find a used one. if only the outer tab of the ear is broken off depending on how much power your planning on making and how your planning on driving i would run it as is for awhile. the cast iron cases are surprizingly strong as long as your not going to race it like that you should be ok.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: A-833 BROKEN!! (Long post) [Re: Jerry] #359625
06/27/09 02:24 PM
06/27/09 02:24 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Well, the bolt hole is still about 3/4 present, and I don't have the broken off piece. I am afraid that it will not hold. The engine it will be bolted to should be low 12's. I am wanting to race it at the local track probably 3 or 4 times a year, but I will probably do more for the first year cuz I will have to tune it not sure how long that will take.
Re: A-833 BROKEN!! (Long post) [Re: knyech1] #359626
06/27/09 02:52 PM
06/27/09 02:52 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
I got input from Wayne at Brewer's, my dad, and a couple others and they all said I should probably look at getting another case. Even if a welding service guarantees their weld, if it breaks, I gotta get it back to them and it would be a huge hassle...
Re: A-833 BROKEN!! (Long post) [Re: knyech1] #359627
06/27/09 05:34 PM
06/27/09 05:34 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I had a car that ran perfect with the upper driver's side ear busted clean off for years. The bellhousing was cracked too. I only figured it out when unbolting the trans and the piece fell out. I ran this particular unit HARD with a set of sticky DOT's. I'd have no problem running it like that. If mine with ran like it did with a missing ear your should be ok because there is meat for the bolt to press on.
Re: A-833 BROKEN!! (Long post) [Re: knyech1] #359628
06/27/09 05:53 PM
06/27/09 05:53 PM
Cab_Burge Online work
Cab_Burge  Online Work
I believe all of the NP833 cases are cast steel, not cast iron so ther a lot easier to weld and repair. If there is 3/4 of the exeisting ear on the case I would get a good grade 8 washer that fits the bolt and that will clamp down on the case and run it
Re: A-833 BROKEN!! (Long post) [Re: Cab_Burge] #359629
06/27/09 06:17 PM
06/27/09 06:17 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
This is the lower driver's side. I will post some pics tonight and you can see if you'd still go with it. I definately thought about just boltin it up and goin.... We will see.
NP833 cases? I am not sure what you are referring to maybe the part#??
Re: A-833 BROKEN!! (Long post) [Re: knyech1] #359630
06/27/09 06:41 PM
06/27/09 06:41 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have plenty of small bearing cases laying around just drop me a PM
Gus
64 Plymouth Savoy
Dana 60
Re: A-833 BROKEN!! (Long post) [Re: knyech1] #359631
06/27/09 11:11 PM
06/27/09 11:11 PM
The NP833 is the model of the four speed transmissions New Process Transmission company designed and built for Chrysler Corp. starting in 1964 Before that Chrysler had used the Borg Warner T10, they where not strong enough for the powerful Mopar motors being develop, sold, and raced back then
Re: A-833 BROKEN!! (Long post) [Re: Cab_Burge] #359632
06/27/09 11:27 PM
06/27/09 11:27 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
It's totaly up to you on what you want to do. I've ran my 833 with a broken upper passenger ear broken off for years and thats hundreds of hard runs, I don't know why they break off but with the bearing retainer centering the trans. and three other bolts holding you'll be ok. I did put a real thick washer on mine with a longer bolt and cranked it down.
Re: A-833 BROKEN!! (Long post) [Re: Cab_Burge] #359633
06/28/09 01:43 AM
06/28/09 01:43 AM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Ok and you are saying that they are not just cast iron but steel mostly and should be easy (easier) to weld? I don't know much I am just a young punk kid (23) and still learn somethin new every day so sorry to be so ignorant!
And rowin4, I guess you put some strain on yours if you are wheels up?? Do you have a pic of your setup?? What did spec you torque your bolt to?? I have a cast iron bellhousing that I will be using, so it should take more ft-lbs from a bolt than an aluminum one I would think.
Re: A-833 BROKEN!! (Long post) [Re: knyech1] #359634
06/28/09 01:47 AM
06/28/09 01:47 AM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Ok now downsized these pics a bit hopefully this will give a little better insight as to what I am dealing with.
Re: A-833 BROKEN!! (Long post) [Re: knyech1] #359635
06/28/09 01:47 AM
06/28/09 01:47 AM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Back view
Re: A-833 BROKEN!! (Long post) [Re: knyech1] #359636
06/28/09 01:50 AM
06/28/09 01:50 AM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
It's a bit dirty I know, nothin a little degreaser, a sandblaster and maybe some silver bullet can't fix. And I want to rebuild it, at least put new gaskets in like I said, but the insides do look nice....
Re: A-833 BROKEN!! (Long post) [Re: knyech1] #359637
06/28/09 02:30 AM
06/28/09 02:30 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I would take me a thick stainless washer, or bushing and weld that thing up with some 308 filler. Pre heat the lug pretty good and fire up the tig. You could easily build that up to be strong enough...
Re: A-833 BROKEN!! (Long post) [Re: Bob_Coomer] #359638
06/28/09 02:45 AM
06/28/09 02:45 AM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Dang...well I don't have a TIG, just a crappy mig lol. I do have access either at the university or through a friend's workplace so that could be an option!
Re: A-833 BROKEN!! (Long post) [Re: knyech1] #359639
06/28/09 11:04 AM
06/28/09 11:04 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
I'd swap cases and be done with it.
If its not a 308 bearing register, now would be time to upgrade. stock is fine for your application imo.
Re: A-833 BROKEN!! (Long post) [Re: theclutcher] #359640
06/28/09 11:44 AM
06/28/09 11:44 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Even when it's not broken, most of the pressure is on the section that is still there. Make sure you have a thick (or doubled up) washer under the head of the bolt and it will be fine.
Re: A-833 BROKEN!! (Long post) [Re: theclutcher] #359641
06/28/09 12:01 PM
06/28/09 12:01 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
The 308 bearing was the O.D. tranny bearing correct?? Wouldn't I have to find a different bearing retainer and do some machining to get my internals to fit??
Re: A-833 BROKEN!! (Long post) [Re: knyech1] #359642
06/28/09 12:32 PM
06/28/09 12:32 PM
The 308 bearing case was for the larger 18 spline input shaft, the O.D. bearing is even bigger tha the 308. Don't forget on swapping the bellhousing hole needs to match the front bearing collar size Do yourself a favor and wait until you can get a new or used scattersheild before putting the 4 speed in the car
