Re: A-833 BROKEN!! (Long post)
[Re: Cab_Burge]
#359645
06/28/09 01:04 PM
06/28/09 01:04 PM
Posts: 486 IL
knyech1
IL
Kinda what I figured. Love those hemi darts and barracudas Well I am thinkin from what I have read, that I will probably go with getting a different case. JUST because not only do I have OCD, but I am also just afraid that I would have to repair it in the end. Now next subject...rebuilding....what is all entailed in this job?? I do not have any literature on rebuilding a 4 speed.
[Re: theclutcher]
#359651
06/28/09 11:09 PM
06/28/09 11:09 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
I'd swap cases and be done with it. If its not a 308 bearing register, now would be time to upgrade. stock is fine for your application imo.
It's probably not a good idea to change to a 308 bearing case these days since the only Chrysler specific 308 bearings available are made in China(junk). MRC/SKF no longer make this bearing.
[Re: 446acuda]
#359654
06/29/09 01:18 PM
06/29/09 01:18 PM
Posts: 486 IL
knyech1
IL
I am making arrangements with Gus for a 307 small bearing case and maybe bearing retainer. Then might go with Wayne at Brewer's for a rebuild kit for her too. I should then have a good, strong, no worries transmission for my "little" 340 lol.
knyech1-
'71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph
"Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B.
'03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
