Torsion Bar #358023
06/25/09 09:25 PM
06/25/09 09:25 PM
Texas
mkbubs Offline OP
mkbubs  Offline OP
Texas
I am in the process of re-installing the original torsion bars back on my '70 Coronet. One of the torsion bars has a chip in it about 1/16" deep and 1/8" long. The shop manual says to replace, but i pulled it off like that. Do i need to replace it or is it safe to use the original one?
Re: Torsion Bar [Re: mkbubs] #358024
06/25/09 09:45 PM
06/25/09 09:45 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I'd replace them as a pair. It doesn't take much for one to fail. It isn't very pretty when one fails.
Re: Torsion Bar [Re: stumpy] #358025
06/25/09 09:52 PM
06/25/09 09:52 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
new ones are in the 200 to 300 range - its worth it - ever have one break?
Re: Torsion Bar [Re: mkbubs] #358026
06/25/09 09:57 PM
06/25/09 09:57 PM
lay your bar on a flat surface and measure in every direction-maybe draw a square on a flat concrete surface-4ft.X 4ft.and use a chalk box to mark the inside with 6 inch squares-use a carpenters square and a friend to lay out a perfect grid-measure height also-if your bar is not bent it's fine-only a skilled blacksmith can straighten a bent torsion bar
Re: Torsion Bar [Re: DJVCuda] #358027
06/25/09 10:02 PM
06/25/09 10:02 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
The nick is a stress riser.
I suggest replacement. The car is no fun to steer when the wheeel is tucked up in the fender.
Re: Torsion Bar [Re: mkbubs] #358028
06/25/09 10:06 PM
06/25/09 10:06 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
When it comes to suspension componets, there's an ol' motto,....".when in doubt?,throw it out!"
Re: Torsion Bar [Re: DAYCLONA] #358029
06/26/09 09:46 AM
06/26/09 09:46 AM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
I thought it was Johnny Cochran who said that.
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
