Alignment specs #356629
06/24/09 01:28 PM
06/24/09 01:28 PM
DES MOINES IOWA
P
PARTSMAN440 Offline OP
P
DES MOINES IOWA
What are good alignment specs for a race car. I will sit back and read and get an education. Thanks.
Re: Alignment specs [Re: PARTSMAN440] #356630
06/24/09 02:19 PM
06/24/09 02:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On my struts I set them at 0 camber, about 1/32 toe
in and 10* caster(chassis car)... a stock front end
should be all the caster you can get, 0 camber, and
if you can get away with it 1/16 toe in... but do a
toe in curve check to make sure it NEVER goes toe out,
that will cause the car to dart back and forth
