Re: Light weight advance springs for Dist
[Re: quickd100]
#355975
06/24/09 09:44 AM
06/24/09 09:44 AM
Posts: 314 North East Missouri
express
North East Missouri
Thanks guys, that's what I will try. Thanks Robert for the chart too! Man when does the stock springs go to full advance ![](/ubbthreads/images/graemlins/confused.gif) Must be 2800 with size of that spring!
[Re: express]
#355976
06/24/09 11:53 AM
06/24/09 11:53 AM
I use the real light Mr. Gasket springs part # 925B.
Full advance is in by 1200 or so.
Works great on the street.
[Re: RapidRobert]
#355981
06/25/09 12:47 AM
06/25/09 12:47 AM
Posts: 1,069 Washington State
70Duster440
Washington State
I don't mean to hijack this thread When Don at FBO set up my distributor, mechanical doesn't start until about 2200 and is all in by 3400. (Of course, with the vacuum advance, it does start advancing at lower rpms). Question is, why pick one rpm level as your target total over another? What advantage would I have with my total (34*) in by 2500 vs. 3400?
Not a hijack at all, that is a legitimate Q. You want as much advance as it will take wo pinging at any rpm/load/temp and engines can have full adv wo pinging in the 2500 range(or sooner). Those #'s(2200-3400) dont sound right
The dizzy was tagged with the specs and I have verified them (total timing @ rpm). Just don't know why he chose them. (And if you've ever tried to talk to Don, well, you know it's a challenge). Maybe I need to experiment. If it will make for snappier response on the street, I'm for it. Thanks.
[Re: 70Duster440]
#355982
06/25/09 08:05 AM
06/25/09 08:05 AM
RapidRobert
You have no mechanical adv until 2200 rpm? just off of idle as the rpms climb you would need the spark to start advancing & I had an eng I was playing with & I used one of those I believe lean burn dizzys w no adv & it got way hot fast from the retarded timing in the driveway just from goosing the throttle. I had a ph conversation w Don @ FBO & it went real well and I even get along w Dave Hughes ![](/ubbthreads/images/graemlins/wink.gif)
#355984
06/25/09 06:39 PM
06/25/09 06:39 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Same here as the Mr Gasket springs work great on my combo. I like a quick advance as long as it don't ping. Helps the low end. Ron
[Re: 70Duster440]
#355986
06/25/09 07:55 PM
06/25/09 07:55 PM
RapidRobert
The black one looks heavier, I would R&R it w (1) of the mr gasket ones & see what you get.
