Re: Light weight advance springs for Dist [Re: RapidRobert] #355990
06/26/09 10:35 AM
06/26/09 10:35 AM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
Yeah, I should have done some more reading before asking. So is the 28 max intial or the amount that comes in with whatever the initial is?
Re: Light weight advance springs for Dist [Re: Jeff_383] #355991
06/26/09 10:59 AM
06/26/09 10:59 AM
Hey bro ask away, this is just like school, the only dumb question is the one that is NOT asked! I learn more info here every day. 28 in the amount that is available in the dist curve and the initial is extra because you can set your initial where it is best for your eng & the curve will stay the same unless you change it(& you should)to get the correct total
Re: Light weight advance springs for Dist [Re: Jeff_383] #355992
06/26/09 11:02 AM
06/26/09 11:02 AM
the house on the left.
cogen80 Offline
cogen80  Offline
28* is the total of the curve. say you set the initial at 10* your total would then be 38*. its the total span the dist will allow between the initial and the total timing. that make sense?
Re: DIZZTRIBUTOR BLUES...Ohh Yahhhhh..... [Re: cogen80] #355993
06/26/09 11:51 AM
06/26/09 11:51 AM
California
70Klassick Offline
70Klassick  Offline
California
Hey Mofreaks,
Whats the story on diz P3690432. Mallory based? I'm trying to replace P4120942. Just got a P3690432 from jegs and what a piece of S#!T ,it is!!!!!
The rivets on the pick-up coil are loose and coil hits reluctor...nice.
The crap&rotor are lame. They are not the black MP4120886 like catalog said should come with it. No ribbing in cap.
The advance weights look nice but are a pain to get to.
I very much want to rebuild my (now beautiful)but very old diz P4120942.
The pick-up coil reads 280 ohms. No good?? Where are the parts?? Thanks for any help!! Kurt
Re: DIZZTRIBUTOR BLUES...Ohh Yahhhhh..... [Re: 70Klassick] #355994
06/26/09 01:39 PM
06/26/09 01:39 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
Thanks for the help, really straightens me out.
Re: Light weight advance springs for Dist [Re: RapidRobert] #355995
06/26/09 04:32 PM
06/26/09 04:32 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
I replaced the black spring with a Mr. G. Now, mechanical starts at around 1200 and is all in by 2100-2200. I set my total timing at 36* and it runs great - seems more responsive and no ping. My son and I measured max vaccuum under load (drove around with vacuum hose coming out of the scoop and into the car) so I can check and tweak the vacuum advance as needed for absolute total advance.
Thanks for the input and suggestions Robert!
Re: DIZZTRIBUTOR BLUES...Ohh Yahhhhh..... [Re: 70Klassick] #355996
06/26/09 10:02 PM
06/26/09 10:02 PM
The pick-up coil reads 280 ohms. No good?? Thanks for any help!! Kurt
The archives state 375-425 ohms and that if any different from these specs(within reason) it will still fire just not run as well as it originally did.
