Dual 4 Barrel calabration question..Help Please... #355864
06/23/09 05:07 PM
06/23/09 05:07 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
I have a 452 (400-with 440 crank) stroker engine with mopar stage 6 heads-(stock) and a comp cam -270 duration with 470 lift with headers and it has two Edelbrock 650 CFM thunderseries carbs on it.
I want to know waht I should use for primary and secondary jetting and also what metering rods and the step up springs should I use?????
The carbs are stock calabration;
Primary Jets-.095
Secondary Jets .098
Metering rods .068 x .047
with orange step up springs
You can post here or send me an e-mail to; glr7069@ptd.net
Re: Dual 4 Barrel calabration question..Help Please... [Re: GLR] #355865
06/23/09 07:48 PM
06/23/09 07:48 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've found the stock calibration to be very close. My buddy runs a 65 belvedere with a similar combo (906 heads though). We have gained nothing going richer.
Doug
Re: Dual 4 Barrel calabration question..Help Please... [Re: dvw] #355866
06/23/09 10:40 PM
06/23/09 10:40 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Thanks Doug!...
anyone else?
Re: Dual 4 Barrel calabration question..Help Please... [Re: GLR] #355867
06/24/09 06:20 AM
06/24/09 06:20 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I agree with DVW, start with the stock jetting. It usually is very close with just some minor tweaking. Dave
