Carbs Vaccum or Mech which is better #355802
06/23/09 03:11 PM
06/23/09 03:11 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Kinda of thinking about a new carb. Which is a better choice for a Street cars that does see some time on the strip?
Re: Carbs Vaccum or Mech which is better [Re: flatiron] #355803
06/23/09 03:26 PM
06/23/09 03:26 PM
organ
maximum entropy Offline
organ
like just about everything else in this hobby, "it depends", on what you're willing to put up with, how good you are at tuning, et cetera. if you're good at tuning, and you go conservative on carb size, double pumpers are fine. the better you are at tuning, the further you can deviate from typical recommendations. if you want minimal fuss, it's tough to beat a good vacuum secondary carb.
Re: Carbs Vaccum or Mech which is better [Re: flatiron] #355804
06/23/09 04:14 PM
06/23/09 04:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
For better mileage you would be better with a vac
secondary... every time you move the pedal you would
only be squirting 1 pump unlike a mech that squirts 2
Re: Carbs Vaccum or Mech which is better [Re: MR_P_BODY] #355805
06/23/09 04:21 PM
06/23/09 04:21 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
vac is better for the street in my experience.
my car had the same et with 2 750 vac sec as it does with 2 750 d.p.
also not all d.p. carbs have a 1:1 linkage for the secondaries so under light throttle conditions you only use the front pump untill you get a little more agressive
WAXER
