drive shaft length change #355799
06/23/09 03:05 PM
06/23/09 03:05 PM
virginia
tigger1 Offline OP
tigger1  Offline OP
virginia
When swapping from an 8 3/4 to a ford 9 inch what would be the difference in drive shaft length? Will be using the same springs as the 8 3/4.
Twin turbo 440 72 barracuda
Re: drive shaft length change [Re: tigger1] #355800
06/23/09 08:29 PM
06/23/09 08:29 PM
southwest Alabama
challenger73400 Offline
southwest Alabama
I've also started researching this and thanks to Laverne, this is what I've found.
center line of axle to centerline of u-joint
8-3/4 = 12.35"
9" w/1350 joint = 11"
9" w/long yoke = 12-1/8"
Re: drive shaft length change [Re: challenger73400] #355801
06/24/09 03:54 AM
06/24/09 03:54 AM
USA
Ron Silva Offline
Ron Silva  Offline
USA
There are lots of different pinion yolks out there and they all vary. You really need to get it together and see if the Driveshaft will fit.
SRT DEMON ONE SEAT
