440-1 intake #355684
06/23/09 01:30 PM
06/23/09 01:30 PM
ma.
roadrunner34 Offline OP
ma.
Building a 493 rb.Going to install 440-1 cnc325 indy heads.13:1 comp.solid roller.Should I go with the 440-2 and a Dominator adapter or with a 440-3 intake?
Re: 440-1 intake [Re: roadrunner34] #355685
06/23/09 01:43 PM
06/23/09 01:43 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
test show a big HP increase with the second application and a dominator will add more.
it causes clearence issues so the 5" tall six pac hood scoop is better.
Re: 440-1 intake [Re: roadrunner34] #355686
06/23/09 03:52 PM
06/23/09 03:52 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
i will be dynoing those two combos saturday on my 580.i will also dyno a indy dualplane.i'll post the results.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: 440-1 intake [Re: roadrunner34] #355687
06/23/09 03:57 PM
06/23/09 03:57 PM
Belle River
Q
QUIKFISH1850 Offline
Q
Belle River
I went with the adaptor on my combo after i read the results of that same testing 500cu 440-1 heads untouched 13.5 comp with the dominator on top.
Re: 440-1 intake [Re: roadrunner34] #355688
06/23/09 04:48 PM
06/23/09 04:48 PM
AndyF Offline
AndyF  Offline
Another option would be to use the Edelbrock Super Victor intake with MW runners. It is designed for the Dominator flange so you don't have to dink around with an adapter.
Re: 440-1 intake [Re: AndyF] #355689
06/23/09 04:49 PM
06/23/09 04:49 PM
AndyF Offline
AndyF  Offline
Here is another shot from the front. I've been pretty happy with the Super Victor intake. It made over 800 hp right out of the box on this 505 motor.
Re: 440-1 intake [Re: AndyF] #355690
06/23/09 10:01 PM
06/23/09 10:01 PM
ma.
ma.
why more power with the spacer?plenum volume?smoother transition to the runners?
Re: 440-1 intake [Re: roadrunner34] #355691
06/24/09 10:08 AM
06/24/09 10:08 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
a think it is a combination of factors.
1. gives flow a ventury effect narrowing and opening up again.
2. adds to the high rise (ram effect)
3. adds more plenum volume important at RPM's and for big cubes
Re: 440-1 intake [Re: roadrunner34] #355692
06/25/09 12:05 PM
06/25/09 12:05 PM
Chicago,Illinois
N
nosboy Offline
nosboy  Offline
N
Chicago,Illinois
I went with the -2 and the adaptor plate.. There is 3/8 inch between the hood and my vents for my float bowls.. I THINK I need the 6 pack hood,,but,, NEVER tried it without the hood to see if the car ran any differently!!!
Re: 440-1 intake [Re: Old School] #355693
06/25/09 12:27 PM
06/25/09 12:27 PM
NC
440Jim Offline
440Jim  Offline
NC
I would recommend testing the -3 (4500) intake with a cloverleaf shaped spacer to give more intake volume like the 2" adapter does on the -2 (4150) intake. You have to draw the line somewhere when testing, but this is the priority I would give:
-2 intake with 2" 4500 adapter
-3 intake with 2" cloverleaf spacer(stack two 1" if needed)
-3 intake with 1" cloverleaf spacer
-3 intake with no carb spacer (lowest priority)
But on a 580 CID engine, I would think the -3X intake would be better.
Re: 440-1 intake [Re: roadrunner34] #355694
06/25/09 03:08 PM
06/25/09 03:08 PM
ma.
ma.
well, I went with the -2 intake and spacer.Other than a port match and smoothing between the adapter and manifold,is there any other work that should be done?
